Stubby antenna recommendations?
FordMedic
Ann Arbor
2023 Bronco WildTrak
I am wanting to change out the regular antenna to a stubby one, but not sure which one to use
Bronco_montana
NV
I got this one and it has good reception.
MAXRACING Short Aluminum Antenna Compatible with 2021-2023 Ford Bronco https://a.co/d/64paFja
RobL2112
Hamburg, NY
2022 Bronco
I got this one: Perfect fit stubby antenna from Builtright Industries. Works great for the rare time I put the radio on, never have had a problem with reception. I live about 15 miles south of Buffalo, NY so it is basically all flat, as usual with these things YMMV depending on where you live, distance to the transmitters and the terrain.
Mlarv
TN
I had one on my F150 a few years ago. I am in-between Knoxville and Nashville TN. Closer to Knoxville. Most of the stations we get here are a long way aways. When I went to the shorter antenna I lost the three stations I listened to.
When I traveled between TN and MO I wouldn't get the stations I normally could get along the route. It was useless in MO because of the area we visit.
I would say if you have solid stations you listen to, and don't plan on traveling into the center of the country the Carven was the one I used. I sold th truck with it on it, and have not replaced it.
Drizz
Andrew
SoCal
2023 BMW X7, 2020 Porsche 911 CS
I’ve got the Ronin Factory. Looks good and seems to work just fine.
RONIN FACTORY Truck Antenna for Ford F150 F250 F350 Super Duty Raptor Bronco Lightning Dodge RAM 1500 Accessories - Anti Theft - Carwash Safe - Short Antenna F150 (4 Inch) https://a.co/d/ekqvBLw
MyATV
ATL
wavydave
G8 GXP, 04 F150 FX4, Wildtrak 2DR, Badlands 4DR
Cravenspeed. BTW, whichever you choose, just make sure you don't buy the Bronco Sport version. They're incompatible.
kevin.gt
Kevin
Canton, GA
I have The Stubby and base stereo. Reception is pretty poor in my area now. Radio no longer finds FM stations when I auto scan 🫤
I never used it because analog FM is terrible anyways even with factory antenna. Guess I was spoiled by 6 yr old basic VWs’ with HD radio. Mind boggling that any new vehicle built this decade doesn’t have HD radio, but I digress
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
i used the stubby brand made in portland when i was living in OR, but now back in MI i need to use the factory. PM me if you want it for shipping only
Raptor Guy
Will
IL
'23 Bronco Raptor | '11 FLHX | '02 Z06
I've always bought stubbies from Cravenspeed. Their quality is top notch and they are all a direct fit with no adapters. Just keep in mind that if you use AM/FM at all then you're not going to be happy with the reduced reception.
1st 75th ranger
jeffrey
nj
yes stubbies look great
i kept my antenna for height reasons lol
if it hits i dont go under this has saved damage many times
Reese
St. Thomas, USVI
2022 Wildtrak Hoss 3.0 & 2016 E400 4matic Coupe
I also went with the Builtright Industries. Zero issues! It is handling the Caribbean sun/weather perfectly.
