- Aug 27, 2023
- 7
- 41
- 28
- Oceanside, CA
- 2023 Bronco Badlands
- Badlands
A couple weeks ago, I got a “Check 4x4” message and Powertrain warning indicator when starting my Bronco in the driveway. I fiddled around with the controls for a minute, and then shut it off before starting it up again. This seemed to clear the fault, and I went on my way.
then, last week, it did it again, and I was unable to clear the fault. I had to get to work, so I noted it and drove to work (3 miles away). It wouldn’t let me select any GOAT modes (I usually drive around town in eco), and displayed that I was in 2H on the dash, and on the 4wd selector. The thing that stood out to me was that I’m pretty sure it shifted itself into 4wd, because I could feel the drivetrain binding in the turns on dry pavement. When I parked it, cranking the wheel at full lock, it came to a full stop without applying the brake at all.
After work, I drove it back home and left it parked while I waited a few days for an appointment to open up at my local dealer. Got it towed to the dealer, and it took several days for them to get a diagnosis to me.
They said that the Sta-bar was bad, along with the harness for it, which was causing the faults and forcing a shift to 4wd.
Is it just me or does that sound crazy? Does the sta-bar disconnect have control over the transfer case?
This is the type of issue I worried about when buying this vehicle. I’m coming from a TJ that I explicitly purchased because it was manual everything and bare-bones simple to work on. It’s just got me worried about how complex of a machine it is, and how something so peripheral can make my car undriveable.
