Just hasn’t been enough of a problem to change anything. I figure that’s my warning that I’m listing to something too loudly
Looking at 4 inches by my check.Man if you can tell me the depth of the enclosure that would be awesome….
Appreciate the reply but I completed my install a while back haha. Thanks though!Looking at 4 inches by my check.
This sub is like a paper mache piece of cr-p.
Looking at these...DVC, 4-ohm
Alpine, 150 watts per coil
https://www.crutchfield.com/p_500SW8D4/Alpine-S-W8D4.html?tp=111
This Rockford lists 75 watts per coil. Does that cause a problem?
https://www.crutchfield.com/p_575P3SD48/Rockford-Fosgate-P3SD4-8.html?tp=111
That looks real nice. How difficult was it to keep that big piece of plastic from rattling?Appreciate the reply but I completed my install a while back haha. Thanks though!
Its a battle, but winnable.That looks real nice. How difficult was it to keep that big piece of plastic from rattling?
I might hit you up for some tips on that but at the current rate it might be 2024 before I do.Its a battle, but winnable.
Ya it’s not easy. I had it on and off about 20 times but I did eliminate 99%. Only time I hear anything is high volume with the sub all the way up but that was just to test for rattles. Normal every day use it’s great.That looks real nice. How difficult was it to keep that big piece of plastic from rattling?
I’m about to tamper with my sub. Anyone have tips on how to remove the panel?
I’m looking for info about the amp he has. I have the sub and would like info about that ampHave you or will you post the details of your install? That looks pretty sweet.
Here is his build thread.I’m looking for info about the amp he has. I have the sub and would like info about that amp
https://www.bronco6g.com/forum/threads/b-o-sub-installed-on-base-bronco-…-sorta….37207/
its a kicker key 500.1. I have added it to my B&O.
Lot of good info in our thread. Thanks for tagging ksjrb03.Have you or will you post the details of your install? That looks pretty sweet.
