What if I had brats and beer?Not sure I wanna 4 wheel behind you !
"Trunk space? What does that mean?I went crazy with mine. It's loud AF also. I'm going to add 2 more 8" Marine Towers also.
Did you happen to take any measurements of the factory sub?was thinking about trying to use factory box with a better sub. Looks like it may need to be a little smaller with an adapter plateI just added a subwoofer to my Outer Banks w/ LUX & B&O Sounds system. In my opinion, the factory B&O sub is not very good. Perhaps just putting a new speaker in place of the factory sub would work, but I think the problem is more likely in the amp, but you wouldn't know until you tried it. It would be really hard to replace the factory amp, so adding an amp and connecting it to factor sub or aftermarket sub would be just as much work, so i opted for an additional sub. I may eventually tune the 8" factory sub to cover the midrange/higher low range frequencies.
I installed a 600W Alpine amp and a 10" Alpine subwoofer tube. All in about $250-300 with parts and wiring. It sounds incredible, i worked as a custom car audio installer and built several state competition winning vehicles... it's not a competition sound, but sounds great. This is my first post so hopefully this works, i'm adding some pics of the factory sub and wiring.
I used my AUX switch #6 for my remote wire, that way i can turn off the "extra" bass when necessary, without having to have a separate bass control knob. If you haven't wired any of your AUX switches yet, it's pretty easy. The hardest part is the glove box... the wires aren't long enough so getting both hands into the small space to splice them together was tough.
I installed a 8 AWG power wire from an empty battery post > new 40A fuse block > Driver's side firewall (gasketed hole already there, no drilling needed). Ran Power down drivers side under the door jams. Grounded near the amp on a factory grounding post. Installed a LOC from the factory wiring. There are four speaker wires going to the factory sub. My LOC had four speaker inputs. Because I've read that the factory B&O system tones down the subwoofer at higher volumes, I wanted a fuller sound without that downscaling. So i used the speaker wires from the Rear left speaker, and one of the pairs from the subwoofer. Ran RCA's from the LOC to the sub. Connect everything, and good to go. Total install time, about 4.5 hours.
Be very careful removing the rear panels. The clips are tricky. I didn't break any of the main clips, but did break some of the small ones. Putting it back together was not easy, and my softtop closure is tighter now.
Wiring:
Factory Sub & Amps (blue wires are my subwoofer > LOC splice)
DRIVER REAR Speaker Tie-in
Sub and amp installed:
no I didn’t, sorry. I didn’t even take it out of its enclosure. If I open that panel up again I’ll send pics.Did you happen to take any measurements of the factory sub?was thinking about trying to use factory box with a better sub. Looks like it may need to be a little smaller with an adapter plate
theres actually a lot of space above the wheel well behind the panels. If you look at the pic of the drivers side you can see how much space there is above the wheel well. I bet a guy could build a custom enclosure embedded into the panel to save valuable save cargo. I was surprised how much space was there when I opened it up. If I’d known I’d have taken it off, taken measurements, and designed a custom enclosure on that side.Awesome post and congrats on the build. I am still waiting for someone to take that wall off who did not have B n O to see if any woofer additions can be done there. Glad you got the sound you wanted.
You won. And if there wasn't a contest, you won anyways..LOL. That's awesome!!I went crazy with mine. It's loud AF also. I'm going to add 2 more 8" Marine Towers also.
that’s awesome work! Unfortunately I need as much cargo space as I can
that looks awesome. I was going for a little more bump, may gain setting is almost zero. You’re going to give the whole town a concert with that beast.I went crazy with mine. It's loud AF also. I'm going to add 2 more 8" Marine Towers also.
That looks like one hell of a boxed Cap on the bottom to me!Also, did you put a Cap in line? Do your lights turn off completely when the bass hits lol. This is nuts! I'm impressed.
I assumed that was a ground plate back to negative to limit multiple large gauge wire running back to negative through the panels. I've never boxed a cap for heat dissipation reasons.That looks like one hell of a boxed Cap on the bottom to me!
Fade all the way to the back and you will quickly see the issue. The rear pods are absolutely worthless. They are the same garbage speakers used in the base system and are not amplified. The B&O soundstage is all in front of you.I’ve only had my bronco for one day, so I’ll admit that I haven’t been able to play with it much yet. But I don’t feel the sub is the problem (although an upgrade would certainly improve the overall sound). I think the issue is no speakers in the middle of the vehicle. All I hear are the front speakers and it’s underwhelming. I’m really disappointed in the B&O so far….
So instead of crawling over rocks, my guess is you will be crushing them with sound? Makes for an easy straight path. Lol. Nicely done Sir!I went crazy with mine. It's loud AF also. I'm going to add 2 more 8" Marine Towers also.
Having a distinct front stage is critical for stereo imaging. Just about every car I built and competed in had no rear speakers at all. Having them would narrow the front stage to the point that there was very little imaging. Impressive systems have most of the attention focussed to the front of the vehicle, and a subwoofer level that is linear to what the front can produce.Fade all the way to the back and you will quickly see the issue. The rear pods are absolutely worthless. They are the same garbage speakers used in the base system and are not amplified. The B&O soundstage is all in front of you.
