Swapped Hard Top to Soft. Trim Piece is incorrect
Sweetair
Bill
2013 SHO, 03 Marauder, '69 S Code XR7 vert Cougar
Hey all. I have a 2023 WT that I got both tops with. I just swapped out the hard top to soft over the weekend. There are two plastic trip pieces that need to be removed in the back bed area to access where the 3 bolts go that secure the soft top to the vehicle. When I went to put the two pieces back on they will not sit flush as the top of them is too long. The bracket/support for the soft top does not allow the trim piece to sit flush now. I just have it in as best it can be but thought I would ask the group if others have noticed this too? I am thinking so.
I am wondering if I can go to the dealership to order different trim pieces for the soft top and just swap the out in the fall when the hard top goes back on.
Thank you in advance.
bozmosis
Minnesota
Ford '21 Expedition
Yikes!
Adam
Missouri
2018 F-250
I have a 23 dual top Wildtrak and Ford did not send those trim pieces. Hit up my dealer and he sent me pics of his with part numbers. Hope it helps.
Ford Bronco Swapped Hard Top to Soft.  Trim Piece is incorrect AE482368-0958-4EDD-96C5-672FA4950BED
Ford Bronco Swapped Hard Top to Soft.  Trim Piece is incorrect AD22D257-A316-4170-92B5-61DD96B90656
Ford Bronco Swapped Hard Top to Soft.  Trim Piece is incorrect 66F3906D-20E8-4092-BBC1-9524512CFB71
