Swapping Sasquatch to Regular Fender Flares may require a little more than planned
Catmandu
SW Florida
2013 Jeep JKU (Officially Sold), 2015 Expedition
OK, so I am not a fan of the wider fender flares on the Sasquatch package and had planned on swapping them for the regular ones from day 1. I just noticed that the end caps of the rear bumper are also wider:
Ford Bronco Swapping Sasquatch to Regular Fender Flares may require a little more than planned 1604330806994
Ford Bronco Swapping Sasquatch to Regular Fender Flares may require a little more than planned 1604330844559
It appears that the caps may also be swapped out.....at least that is what I am hoping for.
Br66co
Alex
WA
1966 Bronco U13, 2015 Explorer Sport Lux.
I've been looking at this and am thinking of ordering the Badlands with 33" tires to get the smaller fender flares/bumpers and selling the 33" tires and buying 35' or 37" tires. The other factor was that the brand of tires that Ford chose to use for the Sasquatch package (35" tires) has very poor PR and company policy's, i will not own tires from or support that tire company. I'm hoping the gear ratio will be the same.
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
Looks like a cap on the cap. Remove the cap when you swap to the normal. Shouldn't require a whole new cap, but who know right now.
Used2jeep
Massachuvian
2007 Crown Vic P71
Would it be the cap or the whole bumper?
Catmandu
Catmandu
SW Florida
While it appears 35’s will fit, they will rub as documented in the overland build. It appears the Sasquatch package also includes the high clearance suspension.
Catmandu
Catmandu
SW Florida
Monster79
E
Alabama
15'Stang, 07'F150, 23',96',93',79'Bronco
It seems that it is just a sealable cap as there appears to be a seam.
It removes.. I yanked on the overland concept ones and it moves like it wants to come off. Even if it doesn't move Ill cut it off and remove the flares all together.
broncoskip
Broncoskip
Maryland USA
F-150
I bet that is just a rubber or plastic boot that bolts on.
dgorsett
colorado
F250, Mustang, Explorer
I would swap my Sasquatch Wheels/Tires/Flares for Badlands 33's. Or I could but standard flares or aftermarket
Wizard1183
Lafayette
2014 Sierra/ 2010 Camaro 2SS
Just dont forget to add the wider flares if you got 35-37" tires. Otheriwse you'll be illegal and spend life in prison according to some :ROFLMAO:
broncoSJ
NJ
2021 Ranger
Doesn't the choice of the 4.7 ratio bump you to SAS? And you need the 4.7 ratio for 35s???
broncoSJ
NJ
2021 Ranger
Sawzall!!
Ford Bronco Swapping Sasquatch to Regular Fender Flares may require a little more than planned 1615584207404
JHawk
Ray
Heartland, USA
Fusion Sport
I noticed that too. I am guessing that a checkbook and visit to the ford parts counter for a replacement cap might fix that.
I think the front may already match??
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
I'm being lazy and quoting myself
On a Badlands with MT , gearing is 4.7 Don't need to regear. On a Badlands without MT, it's 4.46, which can comfortably run 35s, have no issues on the street and the Auto TQ converter will make this work offroad.
Adding SAS to any model will give you 4.7 gears and lockers in both axles
