abisen
Anand
Seattle
Nissan Altima
Is it straightforward to replace badlands Bilsteins with HOSS 3.0? Or not possible.
Bird Dog Off Road
Jody
Chicago, IL
www.youtube.com
Was rocking the Bronc Buster braces on my stock ones but recently switched to the Icon ones.
James Cole
MX
Badlands Sasquatch (hopefully)
Are the fox better in the regard that you can feel less off the road? A less bumpy sort of ride?
Bronco_Buckeroo
Brandon
Washington
2023 Bronco Wildtrak
I haven’t run HOSS 2.0 off road at high speed (only low speed demo), but I’ve done so with the 3.0. Even with fully aired tires, the Foxes soaked up everything and kept me glued to the dirt.
Would love to run the two side by side for comparison, though!
Even if the difference turned out to be “meh”, it’d still be interesting to know and share with others.
vrtical
Doug
GSMNP, TN
Fords
I bought a spare and personally I would rather bust a fuse than the rack. Maybe if I ever need or put the better rack on, then I would up the tie rods.
ezapar
Seattleish
23 Wildtrak LUX
Yeah, I've seen some speed on a pot holed gravel road. The HOSS 3.0 just floated over everything. Like mentioned above, it just soaked up the bumps.
Not a whole lot of travel though with that rear sway bar. But it looks like it would take about 3.0 minutes to completely remove it for a little more travel.
Ford Bronco Tie Rods visual comparison: 2023 WildTrak Hoss 3.0 vs Badlands SAS vs Bronco Raptor IMG_3863
vzqhsg
MI
F-150, Badlands
I was at the dealership yesterday and they had all 3. My current WT, vs the BL I ordered, and a Braptor inside... Thought I'd share the visual comparison. It may just be my eyes, but seems like the WT are larger in diameter than even the Braptor...
Also, the WT Fox's dwarf the Bilsteins... After a test drive back-to-back, the Fox's were quite a big difference.
'23 WildTrak Hoss 3.0:
'23 Badlands SAS:
'23 Braptor:
From a pure sourcing issue why wouldn't they have put the high ends on all three.
vzqhsg
MI
F-150, Badlands
I'm going to put stronger ones on once I take delivery. I have the Badlands being built.
Vandy
Doug
Ford Mustang Toyota Tacoma
Can someone post the HOSS 1.0 just for reference since that's what most of us are getting?
Tex
Cliff
San Angelo
Blowing a fuse doesn't damage anything else that it's protecting. Breaking a tie rod can and will damage all sorts of stuff, including the rack, before you have time to react.
