Towing - 7 Pin harness options
Aztec1382
Sam
F350
Follow?
da_jokker
Jeep Wrangler JKUR
You know you guys can actually watch a thread without having to post. Little blue button near the top. I keep getting excited every time this shows new post only to find out it's just people following. 🤣
BroncoB
Christine
Tampa Fl
Bronco First Edition
Lol all the following. Mine's supposed to be delivered today so I'll post what I get. I won't be able to actually try to install it right away but hopefully you will be able to get the info you need.
Just noticed the other post with the instructions. They say universal kit but the store told me it was Bronco specific. We'll see.
Thurmy7
Kevin
Fullerton, California
Suburban, Tacoma, Patriot
Watching ;)
BroncoB
Christine
Tampa Fl
So the item I received was exactly what was posted by @Rob79 which is the Tekonsha 22551 (made by Horizon Global). It is a generic 7 pin trailer hitch wiring kit with a plug that you can plug a brake controller into. I contacted Tekonsha about compatibility with the Bronco and they really couldn't give me an answer as to whether is was known to be compatible but that it should be. If an existing harness worked with the Bronco, I would think someone would have done it by now and it would be well know here on 6g. I'm not that comfortable trying to find out. Back in the day I had a local alarm shop with the greatest electrical wizard install an alarm in a Durango and they fried the entire electrical system as they weren't familiar with multiplexing which was new at the time. Luckily I didn't bear any responsibility and the alarm shop and dealer took care of fixing it, but I was out of a car for a few weeks while they did the work. Maybe someone with more expertise in this area will carry on and let us know.
da_jokker
Jeep Wrangler JKUR
Well that sucks for sure. You would think simply adding a 12v charging wire and a reverse wire wouldn't be this complex.
jbryant
Jimmy
Indianapolis
Ford Raptor
I got an universal 7 pin conversation kit. Tied into the trailer brake access plug under the driver side dash. The plug has power, ground, brake petal switch input and output to trailer brake. I used the Curt 4 way to get my lights. The universals 7 pin kit has a receiver that accepts the 4 way plug. I’ll try and post some pics. But it was pretty easy to do.
BroncoB
Christine
Tampa Fl
I could be wrong but I think you're just using 4 wires on a 7 pin plug. What we want to do here is get full function 7 pin wiring in the plug.
jbryant
Jimmy
Indianapolis
Ford Raptor
I used the 4 way wires from the Curt harness and tied them into the 7 pin. The 3 other wires for I tied into the trailer brake access harness under the driver side dash.
BroncoB
Christine
Tampa Fl
That sounds like an ingenious idea. Please share the details, looking forward to it.
BAMF
Jerry
Benicia CA
www.bayareametalfab.com
Two 2021 Broncos
We tossed this on last year to get our trailer to AZ. No brake controller yet but it's wired and ready under the dash. No issues with the LED tail lights.
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Does anyone have more information and pics on how to install a full-function 7-pin towing wiring kit? I came across this universal video (5) 4-Flat to 7-Way Trailer Wiring Conversion - YouTube but I want to see a Bronco-specific install before attempting this upgrade on my own.
Blaylock1988
Colorado Springs
2021 Ford Bronco, 2004 Volkswagen R32
So the trailer brake plug was there despite not having the tow package? Can this be done in a way that still lets you plug in the OEM brake controller?
PCDan
Dan
Park City
1968 Ford Bronco
Ford Bronco Towing - 7 Pin harness options 20220504_083041
Perfect. Where did you get the plug ?
