- Jared
- Feb 20, 2023
- 24
- 2,734
- 4,405
- Denton, TX
- 2023 2dr Badsquatch
- Badlands
Isn't covering the gap below the transmission pan an issue? Even if you don't hit the plastic pan, you could still end up catching edges against the plate behind the transmission. The Talons Garage one looks good because it's flat (the RCI I got has an angle and drops a little bit), so you lose whatever that clearance is. But you also have something to scrape against. I don't know, I'm conflicted.
I guess maybe the terrain makes a difference, lots of rolling boulders big enough to fit in there like in a rock garden might make me more concerned something could flip up and hit it. A plate in that case would seem to deflect the rock away or allow you to roll the rock as you go over it. Maybe then you'll just be replacing it more frequently if that's what you're doing (I'm thinking like Gruber and it's many angular rocks).
I'd rather not get stuck with a busted transmission pan, so I'll put it on. There only seem to be compromises, though.
For example, rolling over something like this, I feel like some of these boulders could flip/push up into that space:
But having a trans plate here might get in the way, since you may actually use that little spot of clearance, but then again you might catch the edge of the plate behind it:
