Trickle Charger..12v Port in Center Console Won’t Work
MMBrodsky
Marcos
Montauk
911 turbo
I bought a new Ctek trickle charger. I’ve always used these in my other cars by simply plugging Into the 12v port in the center console. This isn’t working in my bronco. Do I need to replace the fuse in that port? Or is it simply not “live” when the car is off?
Assuming it’s working as Ford intended, Is there a way to charge the bronco without having to connect directly to the battery?
grayshadow
Charles
Humble, Texas
It’s not live when the Bronco is not ”on”. The 12 volt plug in the rear cargo area stays “live” when the Bronco is not on.
MMBrodsky
Marcos
Montauk
911 turbo
Appreciate it. I will check out the plug in the rear. It would be a real pain in the rear to have to open the hood each time I wanted to connect it.
grayshadow
Charles
Humble, Texas
You could wire a 12 volt adapter taped into the #29 space at inside fuse block under the dash on the driver‘s side.
That‘s what I did to have 12 volt power source for a flat towing brake system I have.
MMBrodsky
Marcos
Montauk
911 turbo
Makes sense. Thank you. I also read that doing something using FORScan can make all the ports live 24/7. Good to hear there are a few options.
mds5917
New Jersey
'21 Bronco Badlands, '21 Toyota RAV4 Prime
I’m under the impression that this is only “live” for 30 min after shutdown…
Johnny Mo
Westchester County, NY
teachu2shoot.com
Ford Fusion Energi, Ducati XDiavel
Get yourself a Battery Tender (Deltran) and use the pigtail SAE connector that comes with it, attaches to battery terminals and you can run it out near the bumper or if you have big enough grille slots through there - and maybe a little velcro to the underside and that way it stays hidden - have them on all my motorcycles and quad.
https://www.amazon.com/DELTRAN-USA-...sr_1_9?keywords=Deltran&qid=1642514280&sr=8-9
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
This 100%. Much safer and not pushing it through the wiring system.
grayshadow
Charles
Humble, Texas
Apparently you are correct. I inserted an adapter with a lighted indicator last night and just went out and checked it and the light is off.
MMBrodsky
Marcos
Montauk
911 turbo
Appreciate it. Thank you. I was hoping there would be a live port in the car but oh well. Time to install the Redline hood struts!
DEC
Derek
SoCal
BMW 640, Mustang Bullitt, Mazda 3, Honda Accord,
I’m assuming it’s safe to hook up a trickle charger directly to the battery?
So many cars say to only use under the hood charging points and not to charge directly to the battery.
