Does anyone know if it is possible to turn off the honk when the key is outside the vehicle but the vehicle is running with Forscan? This drives me crazy as it always honks right when I walk by the horn.
Thanks for the below Forscan info! @D2dhanover
Alternative method
Open the configuration tool and select the module BdyCM. Scroll down until you find "Double Honk on leaving cabin". Change to disable, write, restart vehicle and verify it no longer honks.
Double Horn Honk disable | BCM | 726-63-02 | xxx0 | xxxx | xx-- | disables double honk when exiting running vehicle |
Alternative method
