Dark mode via ForScan
acbaldwi`
Aaron
Golden Co
2002 Jeep Wrangle, 2005 for Explorer, 2021 Bronco
Does anyone know if in forscan i can enable a "dark mode" similar to what police explorers use. Were going to do some astrophotography and i would like to eliminate the lights as much as possible while were out there
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,ā€˜21 ExplorerST , RIP 84 & 90 Broncos
You can change Iā€™m your settings. I did it last week. Iā€™m the display settings, you can set it to night mode all the time and vice versa.
ā€˜21OBX
Ken
90Bronco19
2022 bronco outer banks
There is a dark mode in forscan. I do not know what it does so I didnā€™t mess with it.
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
I think they mean ALL lights black out.
acbaldwi`
Aaron
Golden Co
lol you know the bronco can be turned off, right?
lol its more about
when you open your doors and all the lights turn on, open the tailgate and the lights turn on etc... lol ill try the dark mode see what happens
acbaldwi`
Aaron
Golden Co
yes, thsi
when a cop walks up to his cruiser opens the doors... no dome lights no dash etc.... made to be stealth at night
Saltlife4shore
Anthony
New Jersey
2021 Big Bend
What types of stuff does it black out on exterior? Also does just the speed light up in the display?
AZSky
Scottsdale, AZ
Heritage, Mach E, EV6
Following as this was on my mind. When I arrive for star observing in the desert, and need to go again for something inside the car or raise the liftgate, I don't any light to disturb my dark eyesight accommodation or get a beeping and flashing rear lights.
So after it is enabled by forscan, can I switch is on/off if I am out in the wild?
acbaldwi`
Aaron
Golden Co
Sadly no you would then go back in and redo forscan but it disables the cabin lights the tail lights (opening the back) and the horn beeping when you double lock. All other dash lights continue to work but you can manually dim them
