Not so much…Does the frame protective cover help reduce wind noise at freeway speeds? I expect not, just curious.
It’ll stop further rock chips to the area though
Maybe??? Looks like it should, but I would hate to tell you yes and it doesn't. Have to wait until ours is ready to go and double check it.@TURN Todd : I know you're using some OEM parts for the wiper, any chance this solution is likely to also be compatible?
https://www.stickerfab.com/collecti...ight-module-2021-bronco-with-factory-hard-top
I'm pretty sure as long as you guys also use the OEM shroud on the inside i don't see how it wouldn't work.Maybe??? Looks like it should, but I would hate to tell you yes and it doesn't. Have to wait until ours is ready to go and double check it.
Updating as promised...I'm thinking the same thing. I'll know soon enough!
Do you park with the windows down and/or targa top off?had mine for 2 weeks , love everything about it except the odor is still strong. @TURN Todd any idea how long it will be noticeable?
Mine has toned down a lot. It now has kind of a sweetness to it, which covers the dust from off road...had mine for 2 weeks , love everything about it except the odor is still strong. @TURN Todd any idea how long it will be noticeable?
I left all four windows open when parked in the garage for 3 weeks. The order is pretty much gone.had mine for 2 weeks , love everything about it except the odor is still strong. @TURN Todd any idea how long it will be noticeable?
That was either a typo, or you posted this in the wrong threadThe order is pretty much gone.
Just checked mine (as I have a loud rattle coming from the back somewhere)All - I'm trying to diagnose a noise coming from the rear of my top while driving. I'd be grateful if anyone with a top installed could test the amount of play in their rear glass. See video below.
Troubleshooting Steps Taken:
Checked top alignment (front to back) and bolt tightness.
Removed all items from the cargo area and uninstalled the tailgate table.
Drove the same stretch of road with the rear glass open and closed.
Sat in the cargo area during test to isolate the origin of the noise.
The Issue:
The noise/rattle is present regardless of whether the glass is open or closed. You can feel the vibration in the glass at the same time as the noise occurs.
My Suspicion:
I suspect the ball joint that attaches the rear glass to the strut is loose, causing the glass to rattle over bumps (potholes, expansion joints, railroad tracks). The noise has become more frequent over the past week.
Appreciate any insight you all might have!
