[Update SOLVED]: Fuse 36 tapped by... the factory? Spies? Jeep? Aliens?
Status
Not open for further replies.
Strizzo
Bryan
Houston, Tx
Lexus GX460, 1966 Mustang Convertible
Negative. And yeah wiring external lights here would be... dumb.
definitely want to find out what its hooked to. The fuse tap has a 15 amp fuse so its at least not pulling 30 amps through the fuse box, but those wires coming off the relay wiring look barely adequate for even 15 amps.
Bfizz501
Brad
Arkansas
2014 Silverado 2016 Focus
Just to clarify we are ignoring the self tapping screw as a ground? Or will that be a separate thread?
I'm pretty certain by the shitty install and the unclipped zip ties that is a dealer tracker.
My job is installing gps on fleet vehicles. It could be a tracker, but we rarely use relays for those. We DO use those relays for starter kill switches though! Looks like relay is getting power from fuse 36, which is the fuse for
Automatic high beam.
Image processing module A (15amp). Whoever put that fuse tap in installed the fuses backwards btw. The 15 amp factory fuse should be where the 5 amp fuse is on the add a fuse. Follow the brown wire for more intel.
SevenFourteen
SevenFourteen
Washington, D.C.
2022 OBX SAS EG
OP, your fingernails look like youve got some sort of vitamin deficiency
Good looking out! Nope, it's something else. Totally innocuous. So no "hey I saw you on tv, and I think you might have thyroid cancer!" moment here. I do love this community though!
rtaylor
R
ID
19Raptor, 22Bronco
I went to hardwire a dash cam (with the help of many of you good people here) and saw... that fuse 36 had already been tapped. I was not expecting that, because I sure didn't put anything there. I searched here, but didn't find any info on what this is or where it came from. Does anyone know what this is? Also... three ground wires?? MY22 4DR OBX SAS with Lux. And, yes, I am the only owner. Thanks!
Please tell us you work in a 5-sided building. It would make this a lot more fun!
Ford Bronco [Update SOLVED]: Fuse 36 tapped by... the factory? Spies? Jeep? Aliens? 1684425735538
BRBUSTER72
DAVE
NAMPA, IDAHO
'15 XTERRA '16 SUPER DUTY '18 EQUINOX DIESEL
The queertrons and electroids put that on so you can add blinker fluid.
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
Nothing to add but I gotta know what the brown wire goes too. Follow that sucker!
Status
