mrandol
mrandol
Matt
Jeep Gladiator, Ram 1500
How much less? I am thinking using collars and 37’s but have to be under 6’9”
Mine sits between 6’7” and 6’8”.
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
Which is pretty close to my first edition with rpg collars and 37’s. I noticed it was a few inches shorter today as I just got it delivered today
Bronco1972
Tom
Boise, ID
Ford Bronco Badlands Sasquatch Edition
Nicest Braptor I've seen to date. Nice work!
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
RPG Perch Collar Lift - 1.5" front / 2.25" rear ...... Should have gone the other way around to get rid of the forward rake, and give the front tires more clearance. No truck should have a forward rake unless your drag racing it...... Just my opinion, and I'm sticking to it.....
Other than that, nice job......
mrandol
mrandol
Matt
I can understand why you would think that, but that is not the case. The RPG collars were designed for the F150 Raptor and not the true height for the Braptor. If I would have gone reverse the rear end would have dragged over an inch lower. Currently, I have less than a 1/2 forward rake, which is slightly less than the factory rake. I could have gone the same height in all four corners and been close to level, but the rear would still have been fractionally lower.
mrandol
mrandol
Matt
I forgot to mention that it’s like that because the rear spring are very soft.
jmg72
Arkansas
Ford Bronco
How far do the tires extend past the flares?
jmg72
Arkansas
Ford Bronco
About 2.5 inches
Thank you! I am going with the TIS 555 with -12. I just can’t decide on going with a 12.5” vs 13.5” tire. Any problems with rocks kicking up and hitting the sides?
mrandol
mrandol
Matt
I have not had any issues with rocks or chips
c-dubb
Calvin
Braptor, Palisade
How's the view from the front-facing camera?
adamruiz2001
SoCal
Ford SVT Lightning
