Deleted member 13702
Guest
I know this is a subjective question, but any insight to transmission choice when water crossing? I know the Bronco can ford up to 33" of water. I have been told manuals handle water better as long as you don't shift while crossing. My past experience was with a 2001 Ram Off-road edition; where while crossing approx 22"s of water the transmission failed due to water getting ingested in the breather for the transmission(dumb design from dodge since they put the breather valve on the bottom of the transmission). Has anyone heard if ford has the breather routed higher. I don't cross water often since my experience with the dodge, but I would like to be able to tackle any trail and most of the off-roading around me has large water tracks and small streams to ford. Thanks in advance for the input. Also, I am aware that larger tires and a lift will let me ford greater depths, but for now only reference squatched Bronco.
