- Thread starter
- #16
For all the questions:I can see these plugs leaking if spraying directly with a hose but just water splashing up doesn't seem right...I haven't had any issues. Does water drain out w/ the plug installed?
Yes I cleaned out the drain and then reinstalled it making sure it was fitting correctly.
No I never spray out the interior. Water definitely can drain out with the plug closed as it had to be actively sprayed to get that pic. I physically watched the water start coming thru the plug and drain back out again during the test. Water is definitely able to come thru and leave with that plug installed.
Spraying it with the hose was done at a relatively low pressure, and was way less messy than when I experienced it off-road. Bombing thru a puddle at 30 or so made muddy water spray all over the dash. I felt droplets hit me in the drivers seat as well as soaking the back of my passengers legs. I might have a video of it somewhere but I’m not sure
