- Banned
- #16
Yikes.I Does anyone have an answer? Whatever the answer is it's BS.
What does that mean? What can I do?You can... just some options are limited...
be...patient?What does that mean? What can I do?
be...patient?
[/QUOTE
Wow, thanks
Because a hard top is standard on FE (and Wildtrak). On the other trims, a soft top is standard.I just need to know why? I have a FE why am I not able to get a soft top?
I ordered dual tops, as a late October reservation I'll be my22 anyway.
Told em not to change my build.
I didn't want to change my build either, dealer said I had to
No, my dealer doesn't update me on anything. I only found out about April 8 because of this site. I found out on April 3rd.Not to be alarmist, But, you should definitely check in with your dealer because April 8th was the deadline to switch your order to the Mic top. If your had an order for mod top or duel tops and your dealer didn’t update the order, your order might get bumped to MY 22.
but if you try sometimes, you just might find, you get what you neeeeeed.You can’t always get what you want ...
You had to if you wanted to keep your FEI didn't want to change my build either, dealer said I had to
