Weight of Stock Wheel and Tires?
Gaggs11
Gagik
18’ GT3, 19’ Cayenne, 20’ Model S, 87’ Supra
Based on Tirerack listed weight of 52lbs, the SAS wheel is 35.5lbs? The SAS wheel should be a tad heavier than the opt Badlands non-sas wheel, since one is 17x8 and the other 17x8.5.
my guess is the Tirerack listed tire weights must be off. I hope someone can measure the rim and the tire weights separately.
Gaggs11
Gagik
They have the added weight of the beadlock/beauty ring
That is just a “beauty ring.” Should be a thin cover, weighing only a few ounces, but I may be wrong.
webspoke
Stan
Pilot Point, TX
F450, GT350
Weighed the standard badlands and 285/70/17 KO2s today - 78lbs.
Tire rack lists the KO2 @ 51lbs
So stock badlands wheel is 27lbs for 17x8. Pretty light.
broncosor
2022 Bronco Badlands
Interested in having someone actually measure the weight of the sas wheels. We have a deduction thanks to spec weight of sas tire on tirerack but would like to know actual
hotrodjohn
DFW
1966 Bronco, 1975 Bronco Ranger, 1975 Bronco Sport
I saw on here 63 lbs on Black Diamond wheel/tire
Beachin 74
Delaware
I weighed the optional Badlands wheel (beadlock capable) with the BFG KO2 285/70-17.
It was pretty porky at 86.2 lbs. (shown with 33x12.5-15)
Ford Bronco Weight of Stock Wheel and Tires? 2022-01-14 04.42.52
pmi3
usa
Bronco Big Bend
Has anyone weighed the stock Big Bend 17" wheel + 32" bridgestone dueller?
It looks like that dueller may be a ford specific tread.
tbor
Stevens Point, WI
Future 2022 4 door Big Bend Hardtop
Did you ever get the weight on that? I'm selling my takeoffs and need it for a freight estimate.
pmi3
usa
Bronco Big Bend
No sir unfortunately. Will let you know after a friend gets one in this week!
K0Y0TE1
Lukas
Illinois
Dodge Ram/Audi A5
I'd like to know as well. Bronco is hopefully coming up in the next month or so, and I'd like to go aftermarket but try and keep the weight comparable to stock.
tbor
Stevens Point, WI
I have since taken mine off and replaced with Badlands stock tires, 33" KO2's. I would guess they are about 10-15 pounds heavier overall. The duelers are incredibly capable though. Very impressive tire. I just switched for looks and possibly snow for the winter.
K0Y0TE1
Lukas
Illinois
Dodge Ram/Audi A5
Thanks for the reply!
tbor
Stevens Point, WI
Oh also, I have the 2.3l and didn't notice any difference in response with the bigger tires. Drives great if a little stiffer. I'm at 43 psi.
