- Sean
- Sep 18, 2020
- 44
- 530
- 2,117
- Greenville, SC
- Website
- youtube.com
- Bronco
- Outer Banks
Great find. Thanks!Courtesy Bronco Nation.
More like 4-5 Lbs.Those weights likely don't include the 'now standard' headliner. What are we guessing, another 20 lbs?
TheInteresting. Wonder why ??
That, and it provides a rain channel to prevent water intrusion through the seam. Two top pieces butted up to each other would leak.They overlap/interlock, with the driver side on top. But the passenger side needs to support both so it's probably got more reinforcement in the overlap part.
The 4 for is closer than I thought. Never bothered to think about the 2 door. But "thought" is based on perspective.Na, the gigantic glass windows on the 2 door make it heavier.
Interesting that the 2DR & 4DR front panels are different weights. I would have thought they were the same.
Definitely. Taller drivers are going to enjoy the 2-door more for the better peripheral vision and larger front panel opening. This is why Ford should have had a two-door and four-door hardtop at every event... and a four-door soft top, I guess.Slightly bigger to make up for door length?
Anyone have the weight of the 4 dr JK rear cap to compare? Obviously heavier w no middle panel. Hoping I can install some sort of wall mount rack also rather then the hoist we have for the wrangler.That is A LOT lighter than the 4dr jk wrangler hardtop!! I should be able to manhandle the back section on the 4 door and simply install a rack on the side of the garage for it to rest on rather than an install an additional hoist-a-top system! Even if the mod top is 50% heavier or up to 100lbs, that can still be done single handedly (I’m waiting for the mod top) Thank god!
Still worth while to do - maybe not a motorized winch but some sort of pulley system.My neighbor just got a 4D 2021 Rubicon and told me the removable top is over 120lbs. He installed a winch system in the ceiling of his garage so he could remove it.
its also less then an older ford T5 / TKO manual transmission which is about 75lbs yup worthless referenceHow in the hell is the rear section lighter than a bag of quikcrete. That’s absurd.
https://www.bronco6g.com/forum/thre...p-panel-pieces-and-soft-top.14931/post-545155Anyone have the weight of the 4 dr JK rear cap to compare? Obviously heavier w no middle panel. Hoping I can install some sort of wall mount rack also rather then the hoist we have for the wrangler.
