Here you go.
All the weights in an excel file (except MT but easy to add) with my calculated Sasquatch weight / V6 weight / Mid package and lux package weight.
The payload has very little variation with Ford file in some trims mostly due to the ESOF/EMTC.
Key take aways:
If you want good payload Big Bend / base are best. Black Diamond Sasquatched is bad in payload, in fact worst than a sasquatched Badlands (thanks to higher GVWR rating for the Badlands). A good option is a Sasquatched Big Bend + mid package giving plenty of payload.
The V6 2.7 is heavy (152 lbs additional weight) and worsen payload despite slightly higher GVWR (-90 lbs of payload on a Badland). Big Bend wins again here thanks to reduction of only 10lbs of payload when adding the V6.
Ford did a mistake in their file, they list the BD 4 door 2.7 twice and forgot the wild track. I calculated Wildtrack weight approximately.
Key take aways:
V6 2.7 additional weight: | 152 |
SAS weight: | 188 |
Mid weight: | 92 |
Lux weight (include mid/high) | 118 |
