I have had the same deflector on for 2.5 years and have zero whistle. Very happy with it and I believe it pushes bugs/other higher up and over the windshield.Bought my wife a new ā25 OBX. Itās our first time owning a vehicle shaped like a shoebox, so the amount of bugs on the windshield became an instant issue.
Hood deflector was the obvious fix, and I used the Ford OE model. It greatly reduced the bug issue. However, fixing one issue created another; it whistled like a SOB above 40mph. I didnāt think it would bug me, but I couldnāt stand it.
After a little testing using automotive masking tape, I isolated the source of the whistle. It was definitely the airflow on the very front edge of the deflector, in the little void between the edge and where the 3M tape sits. When I covered that with masking tape, it was quiet as a mouse.
So, I went to work finding a solution. I landed on a specific shape of weatherstripping with 3M tape on one edge. The 3M tape sits against the painted lip underside of the hood and the rubber weatherstrip wraps up around the edge of the hood deflector. Used a heat gun to warm everything up, adhesion promoter on the underside of the hood, and patience getting it to sit just right working it across.
The result looks like it came that way from the factory and the whistle is 100% gone, up to a speed of 87 mph on my test drive. (Any faster and I would have time traveled back to 1955. IYKYK)
Very happy with it. For any of you experiencing a whistle that bugs you, 9 out of 10 aerodynamics engineers recommend this solution and the 10th one is deaf.
Hereās the product I used at $12.99 for 20 feet: Weatherstripping![]()
