It appears we have both been around the mechanic block...I had a similar path but got my certs in the early 80s (sigh...how time flies). Folks like us, because we have a mechanical background, probably won't do hard runs and then allow AS to shut the engine down...some others, however, will inevitably operate their vehicles in a less ideal fashion...and shut their engines down (or allow them to be shut down) at inopportune moments. Even if a "modern starter" can last 500,000 cycles, some of our 2.7s have grenaded at far less then that (and valve keepers are supposed to last a lot longer than they did)...quality control is not like it was decades ago with some vehicles. Point being that some of us get just as big of a laugh at the supposed "benefits" of the AS "feature." IMHO, the purchaser of the vehicle should have the option of shutting their engine off only if they want to do so. You may want to research turbos in more depth...it isn't just about the amount of boost reached during a run...spend some time around folks whose primarily occupation is turbo-related, and ask them what their evidence has confirmed. The beauty of having a choice is that you can simply leave your AS untouched if it doesn't bug you...but it clearly bugs some folks (and it has nothing to do with their starter or turbo concerns). Many people in hotter climates hate AS simply for the fact that the AC blows lukewarm during the AS...Not anymore.
I’ve had my own motorcycle shop, went to school to be and was ASE certified in the late 90’s out of high school, I’ve been a small engine mechanic, outboard mechanic, was one of the first down here in FL in my area to get on with the diesel hot rodding garbage in the early 2000’s with a nitrous powered 7.3 F350 (that needed turbo cool down time) , been around motors of just about every kind, turbos, just getting ready to supercharge a 4.0 Ford Ranger. And in today’s day and age, starters and turbos are the least of your worries. Did you happen to miss the article a few pages back of how a modern starters can withstand 500,000 cycles? Do the math on that one. And unless you run your engine hard has hell or under a full load for a long period of time, under boost, and then shut it down immediately after, you will never ever have to worry about your turbo either. Next time you’re on the interstate, bring up your boost gauge in the dash and see where it’s at. If you drive the vehicle like any other, you hardly build any boost to even heat the turbo. Go do some research.
