With winter coming.... anyone tried swapping headlight bulbs from LED to HID (for heat to melt ice/snow)?
4DRS4MRWHRS
4DRS4MRWHRS
Indiana
91' Mustang GT, 14' Mustang GT/CS in GHIG
Not sure you realize the difference between LEDs and HIDs. You're not putting HIDs in these housings without doing a full retrofit (you ever open up housings before?), and that's gonna look all sorts of goofy with the semi-circle shape of the reflector bowls.
It sounds like you think there's a bulb in these things, and there isn't.
You're trying to swap a couple of these mounted in there horizontally...
With these....
I have but I've never opened up ones that had literal led chips only in them. You're right I figured they were like aftermarket led lights where the chips were on a bulb style insert. Well that sucks cause it's hard to see when they get covered and I wasn't even in a heavy storm. Thanks for the insight I'll have to find another way.
jonwithanelcamino
Jon
Nevada
El Camino
Can you wire up a light bar or similar lights on the bumper and flip them on when your headlights ice up? Or would those ice up too?
Lifeliberty
Moonbeam👀
Columbus, OH
Halogens would be fine, leds dont generate much heat. So it would work if you went old school
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
I switch out to old school sealed beams ever winter, right about the time I replace my regular blinker fluid with the synthetic antifreeze type.
Fordtorino93
North Dakota
2019 ford f150
Have you tried a ceramic coating maybe right before the first snow storm? I haven't had an issue yet to the point I couldn't see anymore so I haven't bothered to try it.
tripmcl
Trip
71 Bronco, 2021 Bronco
Rain X helps but my front sensor yells at me for 6 months.
harpo
not as many as I thought
With winter coming has anyone swapped their headlight LED's to HID's? With my headlights freezing up due to the lack of heat last winter I'm trying to get a head start to see if anyone makes a HID kit or installed HID's in their signature lights?!
In the right conditions I had the same thing happen.
By the time it got dark I thought something was wrong and the headlights weren't coming on...
I checked this thread hoping someone may have a simple solution.
brkdncr
Southern California
Toyota 86
I would try to retrofit rear window defrosters (and maybe some of that repair paint) before switching away from the stock lights.
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
I had an FJ Cruiser that the lights froze over as well as the windshield wipers when I driving from MI back to OH. I had to pull over ever 30 minutes to clean them.
I have not had this happen on my Bronco, but now I live in TN so I hope not to see that much cold weather.
I did a quick google search and found a few different companies that make a film or invisible wires to defrost them, but they have to be done during MFG.
On my FJ I used a good wax on the lens every few months. It seemed to help.
