Metal-tech 4x4
Oregon
21'+ 22" Broncos, Lexus GX470, Toyota FJ40
Metal-tech 4x4 Rock Sliders for the 6th Gen Bronco
At Metal-tech 4x4, we build everything with one guiding principle: we actually use what we make, and we use it hard. Our sliders are no exception. These are 100% frame-mounted, 100% bolt-on, and 100% built in-house in Oregon, USA — not overseas, not outsourced.
Mounting System
Our latest mounting system is completely U-bolt-free. Instead, we tie directly into existing features on the Bronco’s frame. The result is a stronger, cleaner install that bolts up securely with no modifications required.
Our Trademarked 2-Stage Rub Rail
Metal-tech 4x4 holds U.S. Trademark Registration No. 4,010,850 for our 2-stage rub rail design. This isn’t just marketing — it’s a proven functional feature:
  • The front rail sits closer to the slider body, ramped forward for smooth engagement.
  • The rail then transitions into a trapezoidal rear kick-out, set farther from the body and ramped back.
  • This design allows you to slide smoothly over obstacles (rocks, trees, ledges), and then the kick-out helps push the truck away, protecting your quarter panels.
Versions Available for 2-Door & 4-Door Broncos
Step Sliders / RRR
  • Flat, wide 2x4" .188" wall US structural steel main body
  • Trademarked 2-Stage Rub Rail with 1.75" DOM tubing
  • Dimple-die fill plates for strength & traction
  • Functions as a strong step while supporting the full weight of the Bronco
  • Includes RRR Pinchweld Guard for a clean look
  • No U-bolts — 100% frame-mounted, bolt-on install
  • Available raw or powder-coated
Sidewinder / RRR
  • Aggressive 25° upward angle for max clearance
  • 2x2" .188" wall US structural steel main body
  • Dimple-die fill plates included
  • Supports full vehicle weight on the trail
Why Choose Metal-tech 4x4?
We’re a family-owned company building what we love, not what investors demand. Every product is designed with the same goal: to get you out there — and make sure you get home again.
2D Sidewinder RRR sliders.
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7385
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7388 (2)
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7387 (1)
2D Step Rock Sliders / RRR:
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7414
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7416
Metal-tech 4x4
Metal-tech 4x4
Oregon
Any pictures from the bottom showing the mounting both on frame and body?
Absolutely. 100% bolt-on, we do NOT touch the body. These are all frame-mounted.
The rear mount picks up the extra-reinforced part of the lower link mount. Clears any aftermarket links without issue. This leaves a very clean line under the frame.
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7397 (1)
4D: Picks points on the face and underside of the frame—100% bolt-on.
For the 2D only:
The front mount utilizes our sub-bracket, which bolts on first, making installation easier. This submount picks up features along the side of the frame and extends under, securing the reinforcement transmission crossmount. 100% no modifications to your frame.
Ford Bronco Frame Mounted Rock Sliders by Metal-tech 4x4 - Made in house here in the USA IMG_7398 (1)
HoosierDaddy
__ Eric
NW. Indiana
What a relief! I thought I had noticed Bronco inventory getting low , I was afraid you guys were getting out of the Bronco game, which would be bad because the reputation your products carry is fantastic. Hard corps, heavy duty stuff !!
Glad to see it was an update /improvement on existing designs!
SierraBronco
For the 2D only:
Very excellent. But I have suspension mounts tied in there and the factory mounts cut off.
Besides the flared-out portion (I prefer them straight for easier sliding) it looks solid 👊🏼👊🏼
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Went to their website. Looks like they offer an angled set as well as a flat set.
SierraBronco
Doesn't look like they will work if you have NVM skid plates installed.
Not that it matters anyway since I need the electric drop steps to get my fat ass in the vehicle.
I just chopped a big chunk off the NVM skids to accommodate the new trailing arm mounts. Just takes a little bit of cutting wheel or sawzall then anything fits!
ScLeCo
Springfield
Charger Hellcat
I just dropped the skids to install an oil pan. What a pain in the penis those fuckers are especially working by myself. I unlike you, don't have a wife willing to get dirty in the garage.
The dog is willing but without opposable thumbs is not much help
SierraBronco
I installed them the first time by myself. Wasn’t easy. She took them off by herself getting creative with a jack, but having both of us put them back on was so much better
Razorback
Bill
Dallas
Lincoln MKX
I've tried to get my dog to hold the flashlight. What a shit show it was. 😂
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Yeah, I’m gonna have to get a set of Sidewinders one of these days.
Oldhippie
Barry
Santa Cruz, Calif.
For the 2D only:
I am a little confused…they look like unfinished prototypes in the photos? Plus I only see three bolts holding them on? I have come down pretty hard (my JCR frame mounted sliders have bent my rockers) for three bolts…but I seem to over engineer stuff…
itwelder
Lee
SoCal
BaseSquatch 2DR
Same question, and why do the welds look like a bunch of trigger welds? And what is the point of the trademark, it's just a picture, which is just marketing; this is not a patent of any mechanical design. Where is the documentation for the "proven" feature?
