- Caleb
- May 3, 2022
- 233
- 1,007
- 843
- St Louis MO
- 2021 Bronco
- Outer Banks
If you’ve been looking to unlock serious performance out of your 2.7L Bronco without sacrificing drivability or reliability, this is it! The Garrett POWERMAX™ Direct Fit Performance Turbocharger Kit is now available, and it’s a complete plug-and-play solution designed by the same team that builds your OEM turbos, just turned up to 11.
The Hardware
Garrett engineered this kit as a direct bolt-on upgrade for the 2021+ Bronco 2.7L. It includes both LH & RH turbo assemblies, each equipped with calibrated electronic actuators for seamless integration with your factory electronics.
Compared to stock:
The Software
Hardware only gets you halfway there. To truly wake these up, pair them with our custom PandaTune powered by HP Tuners RTD.
With our custom PandaTune, we take full advantage of the increased flow and efficiency these PowerMax turbos provide. Refining boost curves, torque management, fueling, and throttle response for smooth, controllable power delivery across the rev range.
This combo completely transforms how the Bronco drives.
Faster spool
Stronger mid-range torque
Sustained top-end power
Factory-like drivability
Whether you’re chasing more fun on the road, extra grunt for towing, or more punch off-road, the PowerMax + PandaTune combo gives you that OEM-plus experience, just way more of it.
Why Panda Motorworks?
We’ve tuned thousands of EcoBoost platforms, and the 2.7L Bronco is quickly becoming one of our favorites. Our calibrations are developed and tested in-house using the same HP Tuners RTD device we ship to customers, so what you get is a battle-tested tune built for your setup.
Garrett 2021+ Ford Bronco 2.7L GT1752S PowerMax Turbocharger Kit
21+ Ford Bronco 2.7 HPT RTD + Panda Tune
Compared to stock:
- +42% compressor flow
- +27% turbine flow
- Supports up to 640 BHP (477 kW)
- 41mm compressor inducer vs. 34mm stock
- High-strength stainless turbine housings rated to 950°C
- CARB Certified (D-871-4) – 100% emissions legal in all 50 states
