- Thread starter
- #31
Thank you for such a detail break down of info. It really helped someone like me (beginner) to better understand my options when it comes to a lift/level kits options. Perch collars wasn’t even on my radar until now.There’s nothing inherently “junk” about a spacer lift but it does have major down sides depending on how you’re using it. The benefit of a spacer lift is it keeps your exact ride quality/strut performance as you remain right in the middle of the window where the shock was designed to perform. The significant downside is it doesn’t limit downtravel so at full droop you’re now significantly more extended than you would have been otherwise and it puts major stress on your CV’s and Tie rods (which is where folks are having issues when they add spacer lifts and don’t know how to offroad properly). If you simply jam a 2-3” spacer up there and do any real off-roading expect to have issues at some point with tie rods/rack and CV’s. With a front wheel off the ground and severely over-extended and it comes down and makes contact w/ traction when you’re on the gas in 4wd the rest is history. Especially on an IFS vehicle as you don’t have the articulation of a solid axle and you’ll get a wheel off the ground a little easier.
Using lift springs on your factory struts has it’s advantages in some regards as it doesn’t add further down travel and stress on factory components but that’s where the benefits likely stop. What it does do though is cause the strut to ride in its “extended” range and you have basically zero down travel because it’s already there. Ride quality will suffer and off-road performance too. It would likely be fine if you’re just trying to achieve a look and for street use.
Another option are perch collars which basically do something similar to lift coils except they just add pre-load to the spring on the factory strut.
The zone 2” lift takes some of both of these techniques which maximizes the benefits and minimizes the downside. It’s a combo small perch collar lift + small spacer lift. It doesn’t add too much down travel which mitigates damage risk and it doesn’t pre-load the spring to the point of riding so high in the extended zone your ride goes to junk. It’s a solid approach if you already have factory Bilstein’s are are not looking to Replace those with a full coilover setup and don’t want more than 2” lifT over SAS. Lots of folks like to look down their nose at non-coilover lifts but they mostly don’t understand the various types and how they work and the upside/downside of each.
I really appreciate it your time.
