2.7 vs 3.5 f150?
BIOHAZARDCYCLES
Thomas
Groveland
2017 raptor 2021 xt6
ok so i have a 3.5 10 speed in my f150 .. the 2023 2.7 is a HUGE let down.. there is literally no boost on this thing in when you launch it , sport mode isnt even close to what it is in the f150 .. seems like the wastegate is always open unless your flooring it.. even then its a huge lag..
luvmybronco
Loudon, TN
1968 Bronco sport, 1969 Bronco sport, 1990 F250 Lariat 4x4, 2015 F150 Lariat super crew 4x4
My 2.7 eco that I had in my f150
Was quicker 0-60 than my buddies 3.5 eco. Not by much but still. You might have an issue. 2.7 is no slouche. Mine would smoke the tires.
Bronco#2
Louisiana
2020 SD tremor
The 2.7 in the f150 is quicker. The 2.7 is definitely turned down from ford. I’d guess the difference in the transmissions is why ford doesn’t give it more in the bronco.
MNBigfoot
MN
Doesn't the Braptor have the same transmission as the Bronco?
Bronco#2
Louisiana
2020 SD tremor
Probably, not 100%.
I just know the transmissions are different between the bronco & f150. The F150’s is beefier.
Raptor911
Raptor911
Broadlands, VA
F150 and ranger >> 10R80 trans
Bronco and warthog >> 10R60 trans
Jazer
Jessica
2.7 OBX
I've never driven the 3.5 F150 but the 2.7 isn't as pathetic as you are making it seem. It's definitely not fast but it feels pleasant to drive and has a little "attitude" in it's own respect. There are definitely certain instances where you can feel the turbo lag more than others usually when paired with the need to downshift but overall the turbos are small enough it's not a significant issue. I would wonder if there is something wrong with yours.. What PSI are you seeing max? Also, there are a lot of factors that can affect the butt dyno perception.
fdchief
Ohio
2023 BadSquatch, 1995 F250, 2018 Rebel R2
Coming from a Livernois Tuned 3.5 platinum explorer to a 2.7 Panda "tuned" Bronco, there is no comparison, and i didnt expect there to be. With that said i feel once actual "tunes" are released by companies like Livernois etc, we will see a huge difference as these 2.7s are pretty detuned from the factory.
Running the Panda Motorworks Module in Sport Mode and on Level 4 of the Tuner, it does wake the Bronco up significantly.
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
If there’s 0 boost from your turbo, sounds like a warranty issue.
LethalPerformance
South Florida
www.lethalperformance.com
Edit: Confirmed the Bronco Raptor has the 10R60 not the 10R80.
LethalPerformance
South Florida
The broncos have a completely different drivetrain and are definitely slower than the F150's with the 2.7L/3.5L's. You can however increase the power of your bronco with either a plug and play JB4 device which will make a significant difference. Other options for more power would be a full flash from Whipple or the Ford Performance procal device with their calibration.
We carry all of it here at Lethal Performance so if you're wanting more power and to wake your bronco up give us a shout and we'll be glad to assist you.
BIOHAZARDCYCLES
BIOHAZARDCYCLES
Thomas
Groveland
YOU HAVE TUNES FOR THE 23 MODEL?
LethalPerformance
South Florida
We're still awaiting emissions approval from Ford Performance on the 2023 MY's. The JB4's work on the 23's as they aren't a flash.
As soon as the Ford Performance 23 tunes are available we'll be sure to let everyone know. You can purchase the device now and once the tunes are available you'll be able to use the device to register with Ford Performance and download the cal file for it.
Let us know if you have any other questions in the meantime.
Thanks!
Raptor911
Raptor911
Broadlands, VA
