I said launch. You said launch control.… Did you just use the word “launch” and “Bronco with Sasquatch” in the same sentence???
Although I hope the Bronco has some good speed to it, I’m also not expecting it to be a Trackhawk or anything like that.
Launch control not required
Pretty sure a 4 door First Edition is heavier depending on the F150, but 100 lbs per wheel/tire is a lot no matter what the gear ratio is. Throw some F150 size tires on and it will flyyyy. I do think applying some brake at launch and using 4A will help a lot, but a 4 door First Edition or Sasquatch Badlands will be the slowest no matter what.I don't speak for the group but I was hoping for wheelies! Something doesn't add up because being a brick is irrelevant for a 0-60 run and the F150 can do this in 6 seconds. Same engine, similar weight, and the Bronco does have heavier and taller tires but it also has 4.7 gears versus the F150's 3.73 gears which should give a huge jump off the line. I suppose we need somebody to do a test with the smaller/lighter tires to see what's going on here.
