2.7L Engine Cover?
HCGxKaLiBeR
CT
2025 BMW X2 M35i
I work on my car a lot, no sweat.
After looking at the 2.7L Engine layout, it triggers my OCD anxiety, I'm like...
Ford Bronco 2.7L Engine Cover? 1635193726268
Yeah, it needs to be covered
Incinr8
1973 Dodge Power Wagon
Part #s for studs?
Incinr8
$100.00 Shipping to So cal. lol
DUSTYcazOREGON
Craig
So here it is - I purchased a new new F-150 cover and two studs to mount it.. The holes in the cover line up perfectly with the tapped holes in the manifold for the studs. The cover itself fits but did require me to trim away some of the plastic on each side to clear the turbo plumbing and wiring on the Bronco. It is currently mounted with just two studs but there is what appears to be some type of clip needed for the center in the rear - I'll have to research that a bit more. I mounted a cheap Bronco emblem on the front of the cover that I found on FB. I might remove the cover and paint it to make it look a bit better. Total cost for everything was about $65. took about 45 mins to trim and mount it.
Looks great. Can you please provide us with a link to purchase AND for the studs? Thanks!!!
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
jvece121
2019 F-150 SuperCrew 5.0 FX4
da_jokker
Jeep Wrangler JKUR
Jeep has a cover...just saying :cool:
Ladder18
Martin
Philadelphia
2021 Ford Bronco Big Bend Full size
I don't understand why anyone would want that dumb cheap piece of plastic sitting there doing nothing.
It actually helps keep the engine clean and easier to clean when needed .
turbodog
Alex
Louisiana
F250, Excursion 6.0
Using Sheehy Ford or CARiD both came to 120 ish with cover, two studs, and two nuts (that has shipping and tax to me included)
@jvece121 if you figure out the back let us know.
GRAYFOX-SVT
Travis
Maine
2004 SVT Terminator Cobra, Bronco Outer Banks
Motors are to be heard not seen keep your bonnet closed.
ok. :). As far as the Bronco goes I can go either way on it. I think it looks better with it but I'm not getting it to open the hood either.
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
Did it make it any quieter?
Due51
Bronco, Silverado
I'd be most concerned with that lid holding heat in. Heat is the enemy.
Skip
Skip
Sweet Home Alabama
2020 Ford Edge, 2024 Holiday Rambler
Did the same with my 2.3. got the ranger cover off ebay, screwed in two of the studs and locked it down. Perfect fit. cleaned the engine bay up a bit, didn't notice any change in sound.
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
Interesting, added protection when the valves explode:giggle:
Theherofails
Thomas
Phoenix
can help muffle the ticking from direct injectors that most people find annoying.
Just wait until you hear the cam phaser rattle..
