2 DOOR Bronco raptor?
should we get both 2 door and 4 door or only a 4 door?
  • Total voters
    186
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Only if they change the rear flares
daddycreswell
Josh
Tenneessee
2013 Raptor, 1973 Bronco
Unless it's an elongated 2-door body on a 4-door chassis, ala the Baja Bronco R...
I'm digging this, I'd order one as quick as I could.
Ground_zero298
Scs michigan
You could raptor out a base and have a better more reliable build then buying a braptor.
Ground_zero298
Scs michigan
Base for $35 leaves you another 45k to build. If you canā€™t make something out of that just get the braptor. Sounds like itā€™s more your skill level.
JohnGalt
Tahoe, CA
2023 Defender 110
Iā€™m totally in the Braptor camp.
After you factor in cost of parts and labor (or opportunity cost of time spent wrenching), loss In ride quality on road, loss in warranty, down time on the rig, and the high potential for rework) . I think a base bronco will cost ā€œall inā€ way more than just buying a Braptor.
However, it be cool to see some reputable streamer do a stock Raptor vs. a Base + $45k build (that includes time/labor cost and other ā€œcostsā€) on road, rock crawling, desert running comparison.
T Copp
Travis
KC
Bronco, Mercedes GLB
This. This is what I want to see as well.
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
I donā€™t want a 2dr raptor, I want a performance 2dr off roader. 3.0, 37ā€, actual articulation, ground clearance, heavier transmission, axles, steering without the ugly flares and useless width So it will fit between trees and rocks, go around corners, and not turtle itself...
RRaptor
Rick
2021 Raptor
I would like a 3.0 version. Long wheel base would be great. If it comes with those nasty flares i will look for some way to put something on like those 5ā€ fender extension adapted for the 2 door.
BigMeatsBronco
Allan
2021 FE 2 door
Yep me too, in fact, thats what Im doing to my FE, turning it into a mini Braptor. Minus the hidious fenders! All the Braptor parts combined plus my FE cost, is NOWHERE near the cost of a Braptor ( if I could even get one)...when you add the absurd markups and $100,000K price tag. Plus I hate 4 doors. So this makes way more sense for me.
