- Joined
- Sep 7, 2020
- Threads
- 0
- Messages
- 69
- Reaction score
- 227
- Location
- Los Angeles
- Vehicle(s)
- None
- Your Bronco Model
- Badlands
360 better than I was expecting TBHAgreed, I’d give up Baja for it.
Also looks like 360 miles per tank.
And the deliberate 2-day stubble - as if he just stumbled in from off the trail into the studio to discuss the Bronco.Flannel again! ??
I'm wondering if these can be activated with ForScan? I know the terrain management can be done with those who don't have it on their Rangers. They just bought the dial and activated it with Forscan.Yeah, but if you have a Badlands with no Sport mode...then what?
I had given it thought that quite anything that is controlled electronically should in theory be enabled/disabled via ForScan.I'm wondering if these can be activated with ForScan? I know the terrain management can be done with those who don't have it on their Rangers. They just bought the dial and activated it with Forscan.
Understood. I’m not rock crawling or need the sway bar disconnect so I’m ordering the Wildtrak - which has sport mode ... sorry I misunderstood your issue. Makes no sense to me.Yeah, but if you have a Badlands with no Sport mode...then what?
It seems logical since the other 4 or 5 GOAT modes will already be there. On the Ranger's they didn't even have the control knob but you can buy it, cut out the hole and activate it so I'm hoping they're all there.I had given it thought that quite anything that is controlled electronically should in theory be enabled/disabled via ForScan.
Does this answer your question?I'm waiting to hear if the 4A mode is an auto-switch between 2H and 4H or does it make the Bronco a true AWD vehicle in that mode, able to drive all four wheels without locking the axles, thus able to be used on dry pavement. The Raptor has the latter but I've heard other Fords with 4A have the former. This video seems to imply it's the Raptor's version of 4A. Here's hoping!
Thanks! I actually had read that a long time ago and I guess forgotten about it. I guess I'm second guessing things at this point. I think it will be like the Raptor's system .Does this answer your question?
(“all road conditions” is understood to include dry pavement)
Yeah. That's messed up. Never heard that before. I thought I was done with my build.I know this has been discussed in the past, but this video clarifies the Trail Turn Assist feature. Previously, it was known that it was only available on automatic transmission. But many didn't think the different engine sizes had any bearing on the automatic transmission and the Trail Turn Assist. In this video, it indicated that the Trail Turn Assist is only available on the 2.7L (which of course is only available with the 10sp automatic transmission).
It’s still vague enough that I’m not totally sure what the system is doing... it mentions automatic 4h selection, but then also “continuously varies power”... there was some discussion about it here in a Ford raptor thread, and I’m not sure they came to a consensus.Thanks! I actually had read that a long time ago and I guess forgotten about it. I guess I'm second guessing things at this point. I think it will be like the Raptor's system .
Every time some says that they have likely not be on the receiving end at the dealer when something in their drivetrain is busted...Magnuson–Moss Warranty Act !!!
