Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Welcome, This is nothing more than a thread to track oil changes, mods and the occasional maintenance item.
Final Thoughts:
If there was only a Base available to me, I’d do it all again! What a fun vehicle this has been. I can’t overstate how capable the platform is out of the box with a decent set of tires. After owning a few Subarus I’m used to the gremlins and ghosts of modern cars, and the Fords appear to be no different.
The Badlands has landed, which means this thread will come to an end for updates. As always, this Base was an interim rig and the next Bronco chapter starts now!
Badlands Build Journal
Boreal Base:
Interim Rig:
2021 2DR Base, 2.3T, 7 Speed
Carbonized Gray
No Options
Current Mod List:
17x9 +12 Black Rhino Warlord
Falken Wildpeak AT3W 285/70R17
MRT Trail Rated Turn Down Axleback
Diode Dynamics SS3 Pro Combo (Ditch Lamps)
Diode Dynamics SS3 Pro Driving (High Beam Assist)
Diode Dynamics SS3 Pro SAE Fogs
Sasquatch Flares
Well, my dealer proposed the dream deal. Ive picked up this 2DR CG Base with No Options. Whenever my Order arrives, we trade out. Some minor mods will be installed on this Bronco, it will be a platform used to develop some unique lighting brackets, Molle Panels, a rear storage/sub box, etc. On order are some KMC Canyons wrapped in Falken Wildpeak AT3W 285/70R17, the 4.46 Gearing should turn the 33's without too much issue.
Ford Bronco The Boreal Base December 11, 2021_8084-LR
Ford Bronco The Boreal Base December 11, 2021_7997-LR
Ford Bronco The Boreal Base December 11, 2021_8055-LR
Ford Bronco The Boreal Base December 11, 2021_-LR-3
Ford Bronco The Boreal Base December 11, 2021_7986-LR
Ford Bronco The Boreal Base December 11, 2021_-LR-2
Ford Bronco The Boreal Base December 11, 2021_7962-LR
Ford Bronco The Boreal Base December 11, 2021_8031-LR
Got them meats
Ford Bronco The Boreal Base 141525F8-ACD5-483D-87AE-4BCB1105EEEC
Ford Bronco The Boreal Base 7323C817-3783-4FD5-91C4-53CF7F0846C9
Ford Bronco The Boreal Base DD8A8E52-F351-4C6A-9016-87306ECEEA8E
Ford Bronco The Boreal Base 1261ADA2-6112-4F8F-AD97-33028128CA79
Ford Bronco The Boreal Base 262EF609-3C2E-44CB-AD4B-E256503E62FF
On a scale of 0-10 for trail experience, give me a 0.5. Got out with the new rubber, turned off advancetrac and she carved through any and all snow that was asked of it. No issue or hesitation
Ford Bronco The Boreal Base 5085D439-6E5A-484D-A939-4005025001EC
Ford Bronco The Boreal Base 8AA6F4F9-9AB3-4BE3-BC1A-F62886AF9B92
Ford Bronco The Boreal Base 973A3726-628E-455B-8351-789E0F580C4B
Ford Bronco The Boreal Base 102379DC-9EF2-403B-8E31-D0AE0A9DC31E
Ford Bronco The Boreal Base F77E6070-E674-4B9B-AF3E-3B0FF397A761
Ford Bronco The Boreal Base 2FC2EF26-49AF-49F4-9F3D-5D9A6C86B453
Ford Bronco The Boreal Base EE954941-FA51-4412-B4A3-69D4EC9C0F4D
Ford Bronco The Boreal Base 33D186B8-62A8-4DF1-9D2E-F47DF1D8D13F
Cabin Run with Bella:
Ford Bronco The Boreal Base January 15, 2022_2155-2
Ford Bronco The Boreal Base January 15, 2022_-9
Ford Bronco The Boreal Base January 15, 2022_-8
Ford Bronco The Boreal Base January 15, 2022_2184
Ford Bronco The Boreal Base January 15, 2022_2196-3
Ford Bronco The Boreal Base January 15, 2022_2178
Ford Bronco The Boreal Base January 15, 2022_-6
Ford Bronco The Boreal Base January 15, 2022_2133
This weeks project on the Bronco: LIGHTS!
From paper to product, I machined some simple brackets out of aluminium, rattle canned them, installed an Auxbeam Fuseblock and am awaiting some RAM stuff in the mail to make the mounting arm for the Interior Auxbeam Switch Panel; The lights still need to get dialled into position. Once my fogs show up and I get them in, We'll get out for some aerial shots.
Beauty Shots first, In Process Shots Second, and some Fun shots finally.
Ford Bronco The Boreal Base January 22, 2022_3115-LR
Ford Bronco The Boreal Base January 22, 2022_2859-LR-2
Ford Bronco The Boreal Base January 22, 2022_2865-LR-3
Ford Bronco The Boreal Base January 22, 2022_2878-LR
Ford Bronco The Boreal Base January 22, 2022_-LR-3
Ford Bronco The Boreal Base January 22, 2022_2949-LR
Ford Bronco The Boreal Base IMG_2673
Ford Bronco The Boreal Base IMG_2700
Ford Bronco The Boreal Base IMG_2711
Ford Bronco The Boreal Base January 22, 2022_2991-LR-3
Ford Bronco The Boreal Base January 22, 2022_2392-LR
Ford Bronco The Boreal Base January 22, 2022_3171-LR-2
Ford Bronco The Boreal Base January 22, 2022_2995-LR
The temperatures dropped to -40 again this week. Had an issue crop up again, I suspect the transfer case is not fully disengaging from 4H to 2H in the cold, its a big WHIRRRR/Ratcheting that's speed related. It threw some powertrain faults; a vehicle restart always solved the issue. Ive got an appt. booked for them to check it out.
I finally got the DD SS3's all aligned and in place. Next time the Bronco gets a wash Ill get out for some night shots. The double pod setup provides excellent coverage and having Zone control is neat, Im excited to do this all again on the Badlands.
Same Same, But Different:
Ford Bronco The Boreal Base February 05, 2022_5063-LR
Ford Bronco The Boreal Base February 05, 2022_4979-LR-2
Ford Bronco The Boreal Base February 05, 2022_4986-LR-2
Ford Bronco The Boreal Base February 05, 2022_4908-LR
Ford Bronco The Boreal Base January 30, 2022_3793-LR-2
Ford Bronco The Boreal Base January 30, 2022_3566-LR
A few wildlife encounters along the way too
Ford Bronco The Boreal Base January 30, 2022_3548-LR-3
Ford Bronco The Boreal Base February 05, 2022_4892-LR
Ford Bronco The Boreal Base January 30, 2022_3665-LR
Ford Bronco The Boreal Base January 30, 2022_3754-LR
Ford Bronco The Boreal Base February 05, 2022_5050-LR
7,700KMS, the starter packed it in. Roadside assistance and warranty came to the rescue. Only six days in the shop for that, a wiring repair and an oil change to boot. Its back in action, we've found some Lynx and the Sas flares came in!
Ford Bronco The Boreal Base February 27, 2022_6954-LR
Ford Bronco The Boreal Base February 27, 2022_7077-LR
Ford Bronco The Boreal Base February 27, 2022_7089-LR
Ford Bronco The Boreal Base February 27, 2022_6983-LR
Ford Bronco The Boreal Base February 27, 2022_6947-LR
Ford Bronco The Boreal Base February 13, 2022_6194-LR
Ford Bronco The Boreal Base February 13, 2022_6284-LR
Ford Bronco The Boreal Base February 13, 2022_6250-LR
Ford Bronco The Boreal Base February 13, 2022_6272-LR
Ford Bronco The Boreal Base February 13, 2022_6275-LR
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
Build Details:
2DR 2022 Badlands, 2.3T, 7 Speed, Sasquatch
(Mansquatch)
Eruption Green
High Package, Tow Package, MIC
ETA:
Who Knows?
Current Mod List:
N/A
Future Mod List (in no particular order):
Modular Bumper or aftermarket with Hidden winch
Baja Designs LP9 Amber Driving Combo x2 (High Bumper Mounted, forward facing)
Baja Designs LP6 Amber Driving Combo x2 (High Bumper Mounted, forward facing)
Diode Dynamics SS3 Max SAE Fog Amber x2 (Low Bumper Mounted, forward facing)
Diode Dynamics SSC2 Pro Amber Combo x4 (If mod bumper)
Diode Dynamics SS3 Pro Amber Combo x2 (Ditch Lamps)
Diode Dynamics SSC2 Pro Amber Combo x4 (Reverse)
Rocklamps, cause the mall can always use more lighting
AuxBeam 6 Gang Switch for full lighting control
BuiltRight Cargo Molle System
TrailRax, or similar
MaxTrax
Krazy Beaver Shovel
Rotopax
"Rocklamps, cause the mall can always use more lighting... " Had me dying of laughter. I have 4 LP6 lights on my truck and love them. I ran into the Baja Design guys at a truck show and they are in the process of adding them to the Bronco bumper the staff owns. Great list you came up with. All quality items.
GaryB2220
Gary
Wellsboro PA
'99 4runner, '10 Town & Country
Up until the aftermarket lights, we have the same build. I'm going to be putting infrared lights and a receiver on my front end. Then just gotta keep it in Baja mode or figure out how to keep it up on the screen. Hoping to see a grill guard soon for maximum coverage and protection from striking deer. Then getting the roush level 2 2.3l performance upgrade kit once they port it over from the ranger. Also needs proper combo rock slides + side steps.
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
I have an OnX6 30” DC on my FXT and have loved it, except the fact that it’s so bright it’s very selective in use. I’m pumped to have High and Low on the LP series and in general more control of independent zones
Juiced21
Danielle
'21 Badlands, '20 Veloster N
Bronco build and a Great Grey Owl?! Amazing!
RunNGunArk
Brad
Fort Smith, AR
2022 Badlands Sasquatch
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Nothin much to update on the Base as of late, I installed some fogs and that's about it. After hearing the rumours of Sasquatch constraints (all other parts will be allocated for non-sas Badland builds) got the news that my order was assigned its VIN, had already been built and is now in transit - Canadian OEM's appears to be much slower on communication than their US counterparts on most fronts.
Until the Badlands shows up, a few more moments with the Base
Ford Bronco The Boreal Base June 10, 2022_6699
Ford Bronco The Boreal Base June 10, 2022_6661
Ford Bronco The Boreal Base June 10, 2022_6740
Ford Bronco The Boreal Base June 10, 2022_6733
Ford Bronco The Boreal Base June 10, 2022_6743
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I cannot convey how awesome some of these pics are.
I have no illusions that I'd ever be able to get these kind of wildlife shots, but what kind of setup were you using to get the shots of you plowing through the snow?
I've been wondering about the cowl mounting positions lately, particularly with regard to an antenna mount. Did you find that the Bronco bolts were really sufficient to secure a mount there on their own, or would you recommend some sort of lock washer or something similar?
(Just seems too good to be true that I could simply remove a bolt, throw a mount or bracket there, thread the bolt back in, and have everything be secure enough for a trail.)
nwGTS
Nate
Chicago, IL
Porsche 911 GTS, BMW M3, VW Golf
This makes me really want my Bronco so I can go bombing around in the middle of nowhere. Hurry it up, Ford.
Great pics. Looks like you were having a blast.
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
These pics are nutty! Not that I'm going to understand a single part of the answer to this question but I'll ask it anyhow. Whats the camera and lens specs?
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
That feeling when your Bronco arrives at the dealership:
Awesome pictures!
I hope to be feeling like a Pup plowin through powder in a few weeks when the Badlands arrives!
I primarily run a Gripped Nikon D850 w/ a Nikon 500mm f5.6PF. I find it versatile and light enough for the day hikes and whatever they may bring.
Regarding the Cowl mounts - in short, they are stout enough for dual SS3's, hell, you could probably put dual SS5's up there with a good mounting bracket and you won't have any issue. The Billet piece I machined has a large contact patch and is very stable; I used the stock M6x1 bolts to snug the mounts to the cowl and some M6x1 with lock washers to attach the SS3's to the mount. The roughest roads around Manitoba haven't budged the lights or caused any vibration during use!
Amazing photos!
You will love every second when you are in the drivers seat!
Thank you all for the kind words about the shots! These Built Wild Broncos really help make each (day)trip even better than before.
