Gamecock
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Thoughts on a track bar being enough to safely run 37s?
That all depends on whether you take curbs at an angle or if you hit them straight on.
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '05 F-350; '07 Camry
I kind of want to see them turn the wheel to full lock. Seems like going to 37s without kicking the rim offset out is going to affect turn radius.
I wanna see a full-lock turn while at full compression on the rocks to get an idea of how much clearance is available, and if any Sawzall time will be needed...
AcesandEights
Ace!
Oregon
DR650
Am I the only one wildly disappointed that this appears to be the one Saavy was working on? Was hoping for a legit build not a 4wheel parts showcase vehicle.
No, you're not the only one. Not a Savvy fan.
Overland_A51
Overland_A51
Missouri
2018 F-150
Thank you @JAGSarge
Agreed, The Timeline is amazing.
Sorry for the delayed response, busy day at work.
Edit: Removed work profession..... thank you @Used2jeep ?
BadBoyBroncoBilly
Bill
Vegas Baby!
E150 Adventure Van, Chevrolet Spark
I’ll be rolling my Badlands 4dr, Sasquatch with a leveling kit and 37” ??
jimbo92
Greenwood SC
1992 Ford Explorer
Something to actually run the 4600 class. Saavy built the Gladiator for jeep to run it last year so the general consensus was they weee building a bronco to run it this year since one was spotted at their shop. Tons of pics of a nice JL build but this is the same bronco that was spotted there. A bolt on lift bronco cruising around hammertown like a forehead grill wrangler at Jeep beech doesn’t interest me. I want moar race truck.
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Its a bronco... Ima take that shit straight on
Bronco4lyfe85
William
2019 Challenger Scat Pack
You know what they say about a man with 37” tires? They’re over compensating for lack of size. The rest of us will stick with the little tires ?
Ford Bronco 37’s and Fox Suspension on Bronco Outer Banks @ King of Hammers (KOH) 1611859717671
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
It's not the size, it's what you do with it.
Bronco4lyfe85
William
Razorback
Bill
Dallas
Lincoln MKX
Showed the wife and she agrees... This is a panty dropper!
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
ZackDanger, I am trying to explain that within reasonable tire sizes (which I would argue includes 37's) your braking system will only be overloaded by excessive additional vehicle mass. Converting your vehicle speed into brake heat is what all brakes do and the ability to do so is more or less constant as you trade brake rotor speed with brake rotor torque. They are 2 halves of the same power equation. Hypothetically you could add much larger tires in which the brake torque limit falls below your tire traction limit. Hypothetically you should also swap in larger axles with proportionally heavier braking systems.
Edit: I see you were joking ;)
Look man, all I know is I built up my JK Sahara into exactly what I wanted... and now it wont stop for sh*t. I have to plan my stops a couple intersections in advance.
Ford Bronco 37’s and Fox Suspension on Bronco Outer Banks @ King of Hammers (KOH) IMG_6119
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Which cage/rack is that? Looks cool.
