- Dusty
- Oct 4, 2021
- 18
- 404
- 1,329
- Riverside, CA
- 2021 Bronco Base 2-Door
- Base
Introducing Recon Pro from ICON Alloys!
The ultimate wheel for any Bronco, Truck, Jeep or 4X4 SUV, Recon PRO features InnerLock™ D.O.T.-compliant bead-retention technology, replaceable HALO Wheel Armor and aggressive 16-spoke styling.
Recon PRO is initially available in 17 X 8.5" size for popular 5-, 6- and 8-lug applications, including the Bronco's 6 on 5.5" bolt pattern in 0mm or +25mm offset. Available wheel finishes are Charcoal and Satin Black, and come with preinstalled HALO Wheel Armor in Satin Black, with the option to order replacement armor sets in Satin Black or Raw Aluminum.
InnerLock™ is ICON's patented, D.O.T. Compliant bead retention system, making these wheels legal on the street and a beast off-road.
InnerLock™ Technology uses a series of high strength alloy bead retention pins inserted through a thickened section of the wheel to act as a fence to physically prevent the tire bead from being pushed away from the wheel's inner lip. This simple but ingenious solution is patented, lab-tested, and has been trail-proven on the toughest terrain from coast to coast.
FMVSS (Federal Motor Vehicle Safety Standards) No.139 Tire Bead Unseat Resistance Test (modified to 10 psi). Results from multiple tests validated the effectiveness of ICON’s InnerLock technology by exceeding the mechanical limits of the machine (over 7600lbs load) without ever de-beading the tire.
ICON's all-new HALO Wheel Armor system is intelligently designed with segmented quarters, allowing for convenient and cost-effective replacement of individual segments if they incur damage, such as from rock rash.
The segmented design eliminates the need to replace the entire set, providing flexibility and efficiency in maintenance. Moreover, the replacement process is seamless, as HALO segments can be installed or replaced without the necessity of dismounting the tire from the wheel. Crafted from high-grade aluminum, these segments are initially presented in a sleek satin black finish that come preinstalled on the Recon Pro. However, for those seeking a personalized touch, HALO is also offered in Raw Aluminum as a separate part that can be easily customized through painting or specialized coating in any color, offering a truly unique aesthetic.
Here's an informative video showcasing the unique features and benefits of Recon PRO with the InnerLock™ Technology and HALO Wheel Armor features.
RECON PRO KEY FEATURES:
Check them out on our website: Satin Black | Charcoal or your favorite ICON dealer!
- Engineered for D.O.T-Compliance
- Patented InnerLock technology (U.S. Patent No. 11,090,976) provides the ultimate blend of on-road safety and off-road performance, ideal for the “weekend warrior”
- Bead-retention system features alloy pins that are removable, reusable, and replaceable
- Hardened bead retention pins utilize a SAE J1926 O-ring seal and are constructed from high strength alloy that is thermochemically treated for extreme corrosion resistance
- Quick, easy, and safe tire installation and removal
- HALO Wheel Armor system constructed of high-grade aluminum with 4 individually replaceable segments
- Aggressive 16-spoke concave styling
- InnerLock & HALO bolt heads are located inside the barrel of the wheel, protected from rock damage
- Application-specific dimensions optimize vehicle dynamics and tire clearance
- Reduced unsprung weight and rotating mass (compared to a traditional bead lock) improves handling characteristics and vehicle dynamics
- Aluminum alloy construction and 3,200 lbs load rating (4,000 lbs on 8-lug version) provides strength properties that are well suited for off-road use
- Charcoal or Satin Black powder coat finish
