BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
The most complicated pressure cooker on the planet that works off black magic, voodoo, fast neutrons, boron, xenon, and some fancy metal rods.
Cherenkov radiation, aka the forbidden night light, is super cool. I think it's the best "sci-fi" part of nuke power. After the primary loop it's pretty much your plain Jane steam powered turbines.
Broncodave
Seattle
Dodge Challenger/Nissan Xterra
"It's not the volts that will kill you. It's the amps".
The one thing that stuck with me from my electronics class.
Fordmanfrombirth
Gary
2022 Ford Bronco Outer Banks
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
Question?
What are the inner workings for a DC Diode?
I know what it does but how does it do it?
EX: A hydraulic check valve allows flow in one direction by using a valve that seals flow in one direction but allows flow in another.
A compensating CK allows flow in both directions just not equal pressure by using a spring/or varying area spool, that the pressure has to over come to flow in the restricted direction.
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
And impedance (Z) in series and in parallel, and inductive and capactive reactance (X), and inductance (Henrys, the best unit name). AC is a whole 'nother beast...
Late to the party, I have a stack of these and pass them out to the apprentices on jobs. From houses to high rises. Space shuttle launch pads, precious metal mines, coal burners, nukes, solar & steam.
From a 9 volt to a lightning bolt, I've done it all.
Ford Bronco A VERY VERY Basic Primer on Electricity 20230120_103901
Redeye84
Tempe Az
What's all the trouble ?
Just lookup Maxwell's Equations
Everything else is intuitively obvious
:D
Would rather use the smith chart for impedance matching, Maxwell is too mathy lol:
Ford Bronco A VERY VERY Basic Primer on Electricity 1674258335350
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
What started out as a simple electrical explanation thread turned into all the elec experts showing up to say “my dick is bigger than yours”. Lol. Everyone gotta speak what they know and confuse everyone else.
Comparing generator sizes
Fordmanfrombirth
Gary
I can still hear my dad saying that exact line.
Fordmanfrombirth
Gary
You have to admit it has been fun to watch.
Jsullivan
Jay
Yeah, interesting comparison w hydraulic check valves
Lookup PN Junction Diode under Semiconductor Electronics. You can prob find great explanations online
in a semiconductor material like Silicon, a diode electrical action can happen when you have P-type and N-type regions adjacent to each other
Pure Silicon is a very poor conductor of electricity. The magic starts when you throw-in P-type or N-type ' dopant ' atoms into the Silicon lattice. Adding a dopant of just one part per Million can make the Silicon material a Million times more conductive. P-type dopant atoms like Boron are missing a valence electron compared w Silicon. N-type dopant atoms like Phosphorus have an extra valence electron
And the real semiconductor electronic magic happens when you have these P-type and N-type regions side by side
PN Junction Diode with No Voltage applied ( aka Zero Bias )
Forward Bias Voltage - Large Forward Current
Reverse Bias Voltage - Very Small Reverse Current
Thanks.
Hydraulics is easy to visualize, electricity not so much.
At least not for me.
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '24 GR Corolla, '94 VFR, '04 SV
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
