Aftermarket Radiator Fans - Any Good?
MEAT_GOD
Kuwait
22 Ford Bronco 2dr, 15 Maserati Quattroporte
Hi. Surprised I haven't found any threads on this, so I guess I'll start my own. I'm considering getting some SPAL radiator fans for the Bronco.
Ford Bronco Aftermarket Radiator Fans - Any Good? 1689929755148
It gets very hot here - 120F+ - so I'd appreciate any increase in cooling performance, but I wanted to know if anyone here had any experience with them for me to decide on whether it's worth the upgrade or not.
spuddy59
Chase
Lubbock, TX
2023 Bronco
I've got nothing to offer, but wanted to follow and ask what kind of engine temps you were seeing. 120...yeesh...I though the 110 we hit a few days ago was rough.
MEAT_GOD
MEAT_GOD
Kuwait
Approximately 200F for both engine and transmission temperatures. Taking it on light off-roading I've noticed it go above 230 on some occasions, which is why I've been staying careful with this thing all summer.
And yeah, 120 is our average. We hit 140 a few years back, too, lol
Ducati1098
A replacement fan would still be controlled by the PCM and come on at the same temperatures. So unless you plan on controlling it differently somehow, there is no benefit. And at that point even a different fan isn't going to cool any better than the factory ones, so it's basically just a waste of money 🤷‍♂️
Lèòn
Jersey
Love your avatar first of all.
Hmm, looks like a job for @Mishimoto , but also aren't there coolant additives and vented hoods to dissipate heat? Get a universal trans fan as well probably.
Not sure what else I can add, more just paging Mishimoto to chime in
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Big Ass Fan on an accessory switch? Or maybe a swamp cooler wired to ignition. These are both great ideas. :whistle:
Ducati1098
We have a few Big Ass Fans in the shop. Those things do move some air!
MEAT_GOD
MEAT_GOD
Kuwait
It'll be wired to the auxiliary toggle switches, so it can be toggled whenever I want it to be.
And I'm not so sure about it being a waste of money; after all, there's actually no information whatsoever on this forum regarding if it is. The only other thread I found regarding the radiator fan and high temperatures is this guy asking a similar question, yet getting dead silence in response.
If it'll be a total waste of time and money? Sure, whatever, I bought a Bronco anyways, so I'm used to that/s. If not? I'll be able to post another thread regarding its benefits, especially to other desert-dwelling Bronco owners. I'd consider the Bronco's engines to be higher-stressed than other engines, so any small change to prolong its life in a more demanding environment is a good one.
Thanks on the compliment for the avatar! I did message you before about yours, which has definitely been an inspiration for mine, lol
As for the transmission cooling, that's not something I've got in mind - at least, I don't think aftermarket radiator fans will do anything for that. If it's ever a problem, I'll likely just upgrade the whole transmission oil cooler rather than just the fan, and at that point, I might as well just get a whole new radiator while I'm at it.
Ducati1098
Yeah I guess waste of money was a poor description. Because that’s subjective to who is spending it and what they consider a waste.
Personally I just don’t see a point. 230 is a normal oil temperature. 205-215 is a normal transmission temperature. Unless temperatures significantly over that, I see no reason to worry.
MEAT_GOD
MEAT_GOD
Kuwait
Not particularly worried, but it's just not a number I'd like to see when cruising. If I ever give it the beans, it's going to creep towards the upper end of what I'd consider to be normal, so any prolonged hard use of the Bronco's going to put it at temperatures that I'm just not comfortable with.
I've had cars overheat on me even during stop-start traffic, so having a stronger cooling solution for traffic jams, where the stop-start nature, low amounts of ram air due to stop-and-go traffic, and the higher local air temperature due to the sun heating the asphalt directly underneath, will definitely prove to be a worthy investment.
Mishimoto
New Castle, Delaware
F-250
Hey @MEAT_GOD - Coolant + transmission temps in the 200F range seems reasonable for the Bronco. We are working on a performance aluminum radiator which fits perfectly with the stock fan configuration. Like @Ducati1098 mentioned, the stock fan is PCM controlled and moves a large, large volume of air. If you are spending most driving time at slower speeds, you could benefit from a pusher fan on the FRONT face of the radiator. This could be controlled via toggle switch to assist in sending air into the radiator. Not recommended as much for 'normal duty' driving as the fan in front of the radiator reduces the overall surface area of air hitting the radiator.
Let us know if we can help with any recommendations for universal fans for your project!
- John
MEAT_GOD
MEAT_GOD
Kuwait
- John
So, essentially, there's no benefit from replacing the stock fans, only maybe adding them on the front of the radiator. Thanks for the input; seems these are a waste of time.
SVTLightning
Christian
Canada
Titan
These temps are mind boggling! I’m upset at 77°F and up. Was about 87-88°F here today and that’s extreme heat haha
Mcloven
Dover, New Hampshire
Porche Cayenne, Hyandai Veloster, Mercedes GLA
- John
When will this be available? Got to pull my stock one out to get all the mud out and was hoping I could just throw one of yours in. I'll volunteer to test! Hahahaha!
