Any guesses when I can get pricing/order a 23' Bronco Subwoofer enclosure?
peetuhr
Peter
Victoria, BC
'93 Range Rover Classic
So, with the new '23 Broncos set to include subwoofers, I'm wondering if it'll be the same sub/enclosure as the B&O one.
You can currently buy the B&O box w/ sub but it's pretty pricey. Obviously, we don't know what we don't know but any guesses if the new one will be cheaper?
Any guesses when the parts department will get an updated part list?
PS - If anyone wants to sell their B&O box, I'd be interested.
Ground_zero298
Scs michigan
I do not have the answer you seek but will bet they’re will be some for sale the first month 23’s start getting delivered.
peetuhr
peetuhr
Peter
Victoria, BC
Tru. I haven't paid attention to these things in the best of times, what's the approx transition point from 22 to 23s?
Ground_zero298
Scs michigan
Will have to wait for those with converted orders to chime in. I don’t follow the production time lines.
MOBRONCO
MO
Edit as I got different info. Had @flip check a VIN for a Raptor without lux, which is a 7 speaker system. It lists different part numbers that aren’t fully in the system for a sub and amp. Looks like the amp may be reused from other systems such as the F150 and Lincoln MKx, and maybe the Fusion? Looks like a little 100 watt amp, part number.
fp5t-18c808-ab / FP5Z18B849A
The sub seems to be a new part number
N2DT18C804AA / N2DZ18C804A
peetuhr
peetuhr
Peter
Victoria, BC
Huh, thanks for the update! I think I'ma just plan to build my own box anyway. Wanna maximize the space in there and the factory box doesn't look like it's gonna be of much use anyway.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’m more interested in the ACM Forscan adjustments to add an aftermarket unit. Is the enclosure a specific part to mount the stock one in the cargo passenger side? Does that space itself allow ample room for one - or does that cubby hole on the lower trims take up that space?
peetuhr
peetuhr
Peter
Victoria, BC
Not too sure about the first part. Folks usually just tap into the front speakers for aftermarket sub amps but there's definitely plenty of space in there if you're willing to dremel out that cubby.
https://www.bronco6g.com/forum/threads/i-made-a-thing-custom-sub-box-build-complete.48823/
redone17
Cold Spring, NY
I just stumbled on that thread right after posting here. That’s a bit more involved than I’m interested in getting. If I can order the parts from a LUX package cargo area - assuming it’s just the side panel and a sub box - minus the speaker itself - I’m thinking this will be a fun winter project.
da_jokker
Jeep Wrangler JKUR
It would be cheaper to buy the aftermarket box that fits in that spot.
Can't find the link right now, but I remember it was like $600 but that included the box and the speaker that bolts right into the factory area.
MOBRONCO
MO
IF you are willing to cut your panel, that would be cheaper.
da_jokker
Jeep Wrangler JKUR
You know honestly you may not even have to cut the panel. I know it sounds crazy but bass doesn't necessarily need a clear earshot. I mean there could be rattling, but I'd be half tempted to stick the speaker in there without the hole and see what you get.
Another alternative is just a drill some holes in that area, sort of like a grill. I'm not quite sure what my plan is, but I know I'm not going to put a bass box anywhere in the cargo area that takes up room. I need all The storage area I can get.
MOBRONCO
MO
The pocket is too deep to have any sub behind it
redone17
Cold Spring, NY
gringoloco
Germany
2023 2-Door
