FonlyBans?
FonlyBans?
You can run the calculator, do a search here for gear calculator.@Cameront9 brings up a good point, is there an issue in running 33" with the sasquatch gearing? I have found mixed info on that part.
Non-Sas Badlands in the 7mt comes with the Squatch 4.70 gears on 33's from the factory. A bit over-geared for the 33s IMO but certainly acceptable.@Cameront9 brings up a good point, is there an issue in running 33" with the sasquatch gearing? I have found mixed info on that part.
Was it always like that? Or is it a new change for MY24?Non-Sas Badlands in the 7mt comes with the Squatch 4.70 gears on 33's from the factory. A bit over-geared for the 33s IMO but certainly acceptable.
Always that way, one of the reasons I went no-squatch n saved $4k at the time.Was it always like that? Or is it a new change for MY24?
No it’s fine. Ford offers 4.46 with 33s on the Badlands.@Cameront9 brings up a good point, is there an issue in running 33" with the sasquatch gearing? I have found mixed info on that part.
Can you please post straight on front and rear shots?285/75/18s - More Narrow and Taller than a Sasquatch Tire. Pictured with a 1" Level Lift on Sasquatch Suspension. Tires Do Not stick out past Sasquatch Flares with +12 Offset Wheels.
Here is the Same Bronco with Icon Suspension added and Paint Complete. Tires Do Not stick out past flares.Can you please post straight on front and rear shots?
Unrelated to the tires, do you have a build thread?Here is the Same Bronco with Icon Suspension added and Paint Complete. Tires Do Not stick out past flares.
I don't have any good straight down the side shots. Hope these help.
Pictures the trim shop took after being worked on.
