Auto Stop/Start Disable (Trailer Tester Method Confirmed)
jayson1980
1971 Ford Bronco; 2017 Jaguar F-Type R
privateer35
Seattle
Ford Bronco 2021
Failed task successfully
JohnnyBronco
Pennsylania
X4
Can you try holding down the dash mounted disable button while starting the vehicle. The dash button has to be manually engaged to disable on an each time you run basis but if you can bypass the switch itself you might be able to permanently turn off the gas-saving feature,
It is annoying since this vehicle does not also include an auto-hold on the brakes like my BMW X4 has
