Automatic On Demand 4x4...is it worth 10 Benjamins?
BroncBro
2019 Tacoma 4x4
I know about it. The lower lorange is the only reason I want it. Course it's std on badlands and thats the trim I want anyhoo!
Is it standard on BL? I know it is for the WT.
That’s also the main reason I want it.
Danager
Dan
Canada
2019 Ford Edge
I really liked it on my 2018 F150 Lariat. Switched to 4A in any inclement weather. Left it on from November through March. I couldn’t tell you if/when or how often it engaged.
Yeah, I can drive in whatever-wheel drive, I can lock hubs, etc. It is convenient and worked well on my last vehicle. It is a welcome addition on my future vehicle.
MNbronco
RC
SE MN
2021 F150 Tremor, 2021 Bronco sport
pulled a snowmobile trailer hundreds of miles in 4A with patchy snow covered roads the entire way, will 100% be on my Bronco. It is the one feature on my f150 that I feel is a real safety feature.
BroncBro
2019 Tacoma 4x4
Looks to be included in BL to me.
Just by the way, that original flyer had mistakes in it. You have to check out the website to be more accurate. the website contradicts itself in a few different places though.
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
That's to be expected this far out. Most folks don't really appeciate how much work Ford has left to get ready for launch at this point in time, and how much can change. So there are typo mistakes, but also changes because things changed...
KyTruckPlant
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 21 Bronco
I guess the general consensus is in downpours or snow, it's worth it.
Thanks a lot for spending another thou of my hard earned money
Ajusaf
AJ
VA
Wouldn't the anti slippery/traction control help with some of the things you guys mentioned rather than spend more $$ for 4A? I never owned a 4x4, just real time AWD (HONDA), which works the same way, when the computer detects it needs to engage 4WD then it will kick in
Lakelife36
Ben
Interior of BC
It’s not as if the two are being offered strictly exclusively of each other. I’ll happily be using 4A during slick/potentially slick on road conditions, and 4H/4lo when off pavement.
Definitely. The other place it'd be useful is turning around in a tight spot on gravel. I've had sketchy spots where I wish I could make a tight turn and have both axles working at the same time.
Rocketeer Rick
Rick
Rochester, NY
Yes, traction control helps. But think of it this way: traction control works by applying a brake at the wheel that slips. 4A works by detecting (or predicting) rear wheel slip, and engages the front to mitigate it. So, in one case, you're getting a reaction that robs torque & forward movement by putting on the brakes. In the other, you're controlling the slip by applying additional drive wheels. One is a negative, the other positive in terms of system efficiency.
