- #31
They should allow you to save it, name it, and share it online.you can click print and save it as a pdf, but idk about saving it to your account
I have had them on previous vehicles. However, it was suggested that it is movable (to under the gas cap filler door). That would be news to me as I thought it was hardwired. I am assuming it has NOT evolved to a non-hardwired version.I'm not trying to be rude but the keypad has been around on Fords since at least 1980. You just have to search the internet or look at vehicles other than the Bronco on the Ford website to see what it is all about.
They look really cool. Seems like this option is worth it to "future proof" the vehicle.Yes, Ford Pass for the phone app. Not sure if this works better or worse and 'needs' the keyless panel.
Yes, factory tow and wiring
Yes, pre-wiring. The Filson package showed a horrid toggle switch / label machine underdash to control lights and accessories. For showed the internal switch panel (beautiful if real) and these are all pre-wired to the fuse box. So, basically you just need to run wires from the engine bay to the accessories but the cabin in clean of wires. BTW, this is the actual Bronco accessories picture I found with the white/grey interior pics. Assume those led light above the rear view are the switches...
All the photos and B&P show the same pad that is used on the Ranger. That one is battery powered and wireless. Ranger owners have moved them around.I have had them on previous vehicles. However, it was suggested that it is movable (to under the gas cap filler door). That would be news to me as I thought it was hardwired. I am assuming it has NOT evolved to a non-hardwired version.
A very early generation was wired. Some fords had them baked into the B pillar.I have had them on previous vehicles. However, it was suggested that it is movable (to under the gas cap filler door). That would be news to me as I thought it was hardwired. I am assuming it has NOT evolved to a non-hardwired version.
Curious. why do you use the keypad? Can't you just open the door with the fob in your pocket?1. Keypad is an awesome feature that I use all the time. Its a must for me.
2. Tow package installed and wired from factory is great. Don't have to mess with running wires...
3. Aux switches are pre-wired to a box under the hood and another inside the vehicle for connecting lights or anything you want powered inside or outside of vehicle.
4. Roof rails look like they are easy to mount/un-mount, so getting it from factory is not that big of a deal, if you can't get them on B&P, just buy them later. Can remove front 2 panels with rack installed, not the middle section(4 door), or rear section.
5. I would think you could fit 32" tires on base without rubbing. Maybe 33"? No one knows yet...
1. Lock my keys in my truck for a day on the beach/lake. No chance of them getting lost or stolen.Curious. why do you use the keypad? Can't you just open the door with the fob in your pocket?
The one on my wife's MKC is not noticeable and is baked into the B-Pillar and illuminates when you get to the door (red on black background). I assumed that it was hard wired. In theory, you could hide it somewhere else then? Thanks!A very early generation was wired. Some fords had them baked into the B pillar.
But the black “puck” style ones have been wireless for quite some time. They are basically just your keychain fob with a keypad and adhesive on the back.
Presumably if you have a Bronco, you would be into adventure stuff such as skiing, hiking, biking, canoeing, etc. where taking a Key FOB that could get damaged, lost or submerged is not ideal.Curious. why do you use the keypad? Can't you just open the door with the fob in your pocket?
Yeah. That’s the nice one. Unfortunately they decided to go with the stick on one for the Bronco.The one on my wife's MKC is not noticeable and is baked into the B-Pillar and illuminates when you get to the door (red on black background). I assumed that it was hard wired. In theory, you could hide it somewhere else then? Thanks!
what happens when you lock your keys in the bronco and the batteries in the keypad die? can you get in or are you stranded?All the photos and B&P show the same pad that is used on the Ranger. That one is battery powered and wireless. Ranger owners have moved them around.
