I have a 4 door '23 outer banks non-sasquatch with Cooper Discoverer Snow Claw 275/65r18 studed winter tires. This Bronco has the full time advanced 4x4 transfer case option. And to get this out of the way, no I've never driven a regular RWD pickup or Jeep at all, although I had a Mustang GT back in '05 and actually this bronco reminds me of its handling.
I'm coming most recently from a '17 Chevrolet Tahoe LS with 4wd/4 automatic transfer case, rear wheel drive. I realize, differently purposed vehicles, mall crawler glorified minivan on 'roids vs the Bronco which is an off road convertible with some inherent compromises that come with that.
I find in the Bronco, in 4 Auto (and to a lesser extent 4H), the rear end breaks loose when accelerating, or turning at speed on plowed/slippery roads surrprisingly easily compared to the Tahoe. I get it, drive like a granny in the winter, but even doing that, going slow, very ginger on the gas pedal, it doesn't take much for the bronco's back end to start sliding especially on slopes while turning or when starting from a standstill on a slippery surface. It is very manageable in 4H and I can deal with it in 4A, but it still makes me a bit nervous. 2H, for me, which I tried just as an experiment, even with the studded tires, is white knuckle scary in the Bronco if there are a lot of other cars around and lanes are tight, even being super ginger on the gas pedal. Also, the Bronco makes a loud grinding sound when sliding. I thought this was the traction control modulating the brakes but it does it even when the traction control is turned off. Is there any kind of damage occurring when this grinding noise happens?
I make no claims of being a good or even average driver, I am below average and bad, so I fully expect the "LERN 2 DRYVE!!!!!1!1!" remarks, but apples to apples why did the Tahoe *seem* to handle better on slippery surfaces? Weight? Is it the Tahoe's limited slip differential vs. the open/locking differential with traction control in the Bronco that sacrifices on-road slippery performance for off road performance with only 3 wheels potentially on the ground? I also have a bronco sport outer banks and hate to say it but it handles better on-road in winter than regular Bronco, unless the snow depth gets deep enough to make it a ground clearance battle. I live in Alaska (and have for a decade) so that happens.
Also, it seems in 4 auto all 4 wheels rermain driven all the time according to the "off road" display screen on the digital dash. The owners manual says this about slippery GOAT mode:
'Note: Depending on the four-wheel drive
mode selected when using slippery mode
on dry/hard pavement, your vehicle could
experience vibration, driveline bind up,
damage and potential excessive tire and
vehicle wear.'
I presume this statement references the possibility of selecting 4H/4L in slippery mode in regard to the possiblity of damage? Is the digital dash's "off road" indicator accurate or does it just default to showing all 4 wheels driven if you select 4 auto via the drive mode switch or a GOAT mode?
I plan to attend an off-rodeo and ask some of these questions but is there a definitive answer on whether or not 4 auto slippery exacerbates wear on the drivetrain in intermittent/mixed dry/slippery conditions, beyond normal, expected usage?
Anyway, I hate to say it but for a safety minded winter vehicle I don't think the Bronco is a top choice unless I'm doing something wrong with my drive and GOAT selections. That's probably not news to most of you but I'm not a hard core "car/truck guy". Was hoping this was not going to be the case because the newer Tahoes have bad ground clearance due to independendent rear suspension and the rear control arms hanging down absurdly low; don't like subarus for similar ground clearance reasons.
vehicle wear.'
