kojack19
CT
Ford F150 Raptor
Love your build! Curious to hear your thoughts on the Mickeys...They look like a great tire. A bit heavier than I would like but hopefully the durability is there. These came out around the time I got my Gen 3 Raptor. I ended up going with 37 BFGs but these just look like they belong on the Bronco.
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
You hit the nail with the weights.
I like everything about the MTs, however the only reason these arenā€™t 37ā€ is the weight. #20+/- per corner is just too much.
BFG KO2 - 315X70R17LT FP Ford Performance - Load C - 62#
BFG KO2 - 35X12.5R17LT Raised White Letter - Load E - 66#
BAJA BOSS - 35x12.5R17LT Blackwall - Load D - 71#
BFG KO2 - 37X12.5R17LT FP Ford Performance - Load C - 63#
BFG KO2 - 37X12.5R17LT Raised White Letter - Load D - 69#
BAJA BOSS - 37X12.5R17LT Blackwall - Load D - 82#
If/when I go to 37ā€ Iā€™ll go back to the KO2s. (White Letter)
Iā€™ve ran both tires and both have performed great, I just prefer the M/T
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
Wifeā€˜s WT w/ HOSS 3.0 vs Mine
Ford Bronco Badlands NJ Marsh & Pines Build II 976826B7-A2DB-4233-8CA9-A0363DFE3B0B
Ford Bronco Badlands NJ Marsh & Pines Build II 38C709F4-F813-461B-8F86-AA983B8B72BC
She was looking pretty beefy when she brought it home. I think I have her now. šŸ˜œ
Just_Jim
Minnesota
2021 Big Bend
Cutting the crash bar mounts is not a scary experience. The JKS kit really cleans up that space behind the bumper.
I'm only running 35's and needed the clearance for my King reservoirs.
Ford Bronco Badlands NJ Marsh & Pines Build II PXL_20221024_210028483
The DV8 skid plate comes out too far for the King mounting brackets, and they sit really low in harm's way with them anyway. Now they're up high and protected by the bumper.
Baja Bronco
2Sun AZ
Got out for an actually ride in the warm weather and grabbed some better images. Front end feels better now. not sure why. lighter.
It looks so damn good like that! I just don't want to void my warranty.
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
Ford Bronco Badlands NJ Marsh & Pines Build II 85E4D22E-3DEA-48DC-B397-9A84848A712B
Ford Bronco Badlands NJ Marsh & Pines Build II 03E3B436-3C4A-4D60-B890-E90BD89D484A
Ford Bronco Badlands NJ Marsh & Pines Build II F0D7724C-2682-451B-8223-88190E7BF93B
Ford Bronco Badlands NJ Marsh & Pines Build II 3F6D97DC-C9B5-425A-A289-D35A53D662B0
Ford Bronco Badlands NJ Marsh & Pines Build II 1080D689-DBAD-47B2-B05D-F4DFD19F5F07
Ford Bronco Badlands NJ Marsh & Pines Build II EE5C5FCE-6E0A-462D-85E2-F30BBF5BC3DB
Ford Bronco Badlands NJ Marsh & Pines Build II 89875F3E-F1DA-4A37-B3B2-DBD6698847F2
Ford Bronco Badlands NJ Marsh & Pines Build II F00DB75C-B8BD-473E-B418-E86B3B881D5E
Ford Bronco Badlands NJ Marsh & Pines Build II 9DC5F781-57E9-4609-93C8-CB29F780A855
2022 2-Door Badlands w/ Badlands Special Suspension HOSS 2.0 (Yellow Bilstien)
2.3l Manual Transmission 6 speed w/ Crawl Gear - M210 Axels 4.70 Gears
Suspension Lift
Eibach Pro-Truck Coilovers Stage 2
MFG Link ā€”> https://eibach.com/us/2969/E86-35-056-01-22-FORD-Bronco-pro-truck-lift-stage-2-coilovers
Features ā€”->
Install ā€”>
PDF ā€”> https://eibach.com/us/pdf/340012
SPC PERFORMANCE ADJUSTABLE UPPER CONTROL ARMS
SPC Performance 2021+ Ford Bronco Adjustable Upper Control Arms - 25690
MFG Link ā€”> https://www.spcalignment.com/index....part_description&pid=25690&Submit_form=Submit
PDF ā€”> https://www.spcalignment.com/instructions/25690-INS_WEB.pdf
ROCK JOCK REAR LOWER CONTROL ARMS & TRACK BAR
RJ-182601-101 - 2021-up Bronco Rear Lower Johnny Joint Control Arms
MFG Link ā€”> https://www.rockjock4x4.com/RJ-182601-101
RJ-181400-101 - 2021-up Bronco Rear Trac Bar Relocation Bracket
MFG Link ā€”> https://www.rockjock4x4.com/RJ-181400-101
RJ-183400-101 - 2021-up Bronco Johnny JointĀ® Adjustable Rear Trac Bar
MFG Link ā€”> https://www.rockjock4x4.com/RJ-183400-101[/QUOTE]
Product Info ā€”>
Steering & Tie Rods
JKS Steering Sleeve Kit
MFG Link ā€”> https://jksmfg.com/products/steering-sleeve-kit-ford-bronco
Broncbuster Stage lll heavy-duty passenger billet aluminum housing
MFG Link ā€”> https://broncbustertx.com/products/passenger-rack-and-pinion-billet-aluminum-housing
Install ā€”>
Broncbuster Bushing Kit
MFG Link ā€”> https://broncbustertx.com/products/product-name
Install ā€”>
*Opted to not purchase/Install but may in the future. Requires gas tank to be dropped.
RJ-182501-101 - 2021-UP BRONCO REAR UPPER JOHNNY JOINT CONTROL ARMS (ALUMINUM W/ ROCKNUTS)
MFG Link ā€”> https://www.rockjock4x4.com/RJ-182501-101
NJRoadkill
NJRoadkill
South Jersey
www.instagram.com
How are the eibachs?
Iā€™ll let you know. theres still another days work on the lift. Alignment. Plus time to settle in. But they feel solid and look great.
kojack19
CT
Ford F150 Raptor
Iā€™ll let you know. theres still have another day of work on the lift and alignment to do. Plus time to settle in.
Sounds great and just in time for the weekend. Bronco looks awesome-really great build.
Arokcrwlr
Kraig
US - Alabama
Great build! I'm doing basically the same thing - just got make time to do the installs. I've got Eibach COs, Rock Jock control arms (upper/lower), Icon winch bumper, Warn ZEON 10s, and JKS tire clearance kit in the garage ready to go... How difficult was the rear upper links to install? For some reason I dread dropping the gas tank.
