Baja Designs Reverse Kits
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We've now made it a little easier for everybody to order a reverse kit with Baja Designs Lights
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco
We now just give you 1 landing page where you can select your options. We've also added more options then the standard Baja Designs kits (we can do this because we stock a lot of lights and can swap out lights prior to shipping the kits).
So now you can select from a pair of S1, S2 Sport, S2 Pro, Squadron Sport or Squadron Pro.
We also let you select upfitter control or a toggle switch.
And of course you have the option to add a license plate mount for your spare tire (which also includes some LED license plate bolts).
The reverse kits are in stock as of 9/16/2021 at our warehouse.
Ford Bronco Baja Designs Reverse Kits 1632012172507
Ford Bronco Baja Designs Reverse Kits 1632012188534
chtucker
Kirkland, WA
FJ Cruiser
Would the bracket work well with a 10" S8 Lightbar in the work seen pattern (if you don't need the license plate relocate). I don't like the look of the pods hanging there. Kinda like this one (except the light is at the top of the tire
Ford Bronco Baja Designs Reverse Kits 1632019913703
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I like that also. I'll see if a 10" S8 fits and let ya know
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Please let us all know
Of course. If it doesn't fit and there is enough interest we'll just manufacture a bracket to make it work.
I wish Ford left factory bolts under the rear bumper like on the F150/Raptors. They put factory bolts EVERYWHERE else for accessories but forgot the rear bumper? Bleh.
604Bronco
British Columbia
www.bronco6g.com
Is that to show the people tailgating you who's boss? lol
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That and so you can see behind you :) The factory reverse lights are less then desirable. They are better then halogens but man with a set of S2 back there, it's awesome!
604Bronco
British Columbia
www.bronco6g.com
Oh, yes, I suppose that'd be another good use for them too ;) Reverse lights seem to be terrible on most vehicles, sadly. Thankfully we have the aftermarket to improve that! :)
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Indeed. For those vehicles with halogen bulbs we actually have our own brand (CrystaLux) of LED Replacement bulbs which are insane. I'm pretty sure all the Broncos have LED tails from the factory right?
For example here is a Gen1 Raptor with our plug and play reverse bulbs
Ford Bronco Baja Designs Reverse Kits FB-Square3
chtucker
Kirkland, WA
FJ Cruiser
Nope, I do a lot of work at night and in extreme weather/power outages.
This is the light the S1s in the work pattern provided during a storm last night that I was fueling generators/troubleshooting power issues
Ford Bronco Baja Designs Reverse Kits IMG_2772
Ford Bronco Baja Designs Reverse Kits IMG_3195
On the front of the truck I have a 20" VisionX Shocker Race, 2 Rigid DOT Fogs, 2 Rigid 360 Floods
Ford Bronco Baja Designs Reverse Kits IMG_2795
Ford Bronco Baja Designs Reverse Kits image0(2)
chtucker
Kirkland, WA
FJ Cruiser
See my post- A lot of times I think those ambient lighted photos don't do a great job showing the differences between lights- You need to go out in the woods.. I had the advantage that the power was out.. so no one had any lights on.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Ya mean something like this as a real world example :)
Ford Bronco Baja Designs Reverse Kits Reverse Lights (Gen 1 Raptor) #1
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Nope. Standard has halogen rears in Base, Big Bend and Black Diamond.
Can we confirm that’s an eligible swap for the Bronco? I’d order a pair.
I also would like a pair of pods - but, want to hold our for a bumper solution.
MOON
2011 Jeep Grand Cherokee
Are you planning to make these same bulbs for the Bronco? Those photos are amazing.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
No the Bronco uses a weird size bulb and it's not worth the $$ to bring in a replacement bulb that only works on a select # of vehicles. We already sell a few reverse "kits" on our site
