- Adam
- Aug 30, 2021
- 355
- 4,382
- 5,844
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Diode Dynamics did it again. They've finally come out with their Bronco Reverse Kit! A lot of our customers have been installing Diode Dynamics lights under their bumper or mounting them to the spare tire using some off-brand mounts. But there was never a "CLEAN" solution to the wiring. Well look no further!
The new Diode Dynamics reverse kit is truly plug and play! The kit includes a harness that plugs right in line with your factory tail lights. So there's no cutting/splicing involved!
These are due out October 21st so get your order in now and we'll get it shipped to you once our inventory lands!
IN STOCK NOW: https://www.4x4truckleds.com/diode-dynamics-stage-series-reverse-light-kit-for-2021-ford-bronco
Plug and Play. The harness included with this kit was custom-designed specifically for the Ford Bronco and allows for easy plug-and-play installation. Thanks to custom-molded OEM connectors, the harness plugs right into your factory tail light for easy installation and operation. With the included OEM auxiliary switch adapter wire, you can override the vehicle signals and turn on the main beam anytime with your factory switches. No cutting, drilling, or additional wiring needed! The kit operates as an additional red accent light, with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse.
Backlight Functionality. The Stage Series LED pods included with this kit feature a distinctive backlight in a vibrant red color which functions as an additional accent light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products. If you do not want to use this feature, it can be disabled.
- Allows you to mount SSC1, SSC2, or SS3 pods to the spare tire on the 2021-2022 Ford Bronco.
- Custom-designed harness for simple wiring, with OEM connectors and aux switch override.
- Provides high-power reverse light, and red accent light.
- Bolts on to spare tire carrier using included 60mm or 90mm extension lugs.
- Designed and assembled in USA.
