Base 2 door, only 12V power point (cig lighter) in cargo area????
rgalvinmi
Bob
2022 Ford Bronco 2 Door, 2022 Ford Maverick Hybrid
I have a 2 door base....is the only place there is a 12V power point, the cigarette lighter power point, in the "cargo area"??? I have 2 -USB/cell points, I of each in front cubby hole and in rear console back. Do I actually have to plug my GPS in the cargo area...?
BroncoPls!
Austin,TX
23 Rivian R1S, 22 Bronco
Not just Base, I have a 2 door loaded Badlands and the rear is the only place there is a 12 volt receptacle
rgalvinmi
rgalvinmi
Bob
You should also have one inside the center armrest.
Thank YOU! you are correct...there is one hiding in the back of the console, the tray hides it pretty well. Thanks!
philly3227
john
warren, ohio
2019 ford ranger 4 x 4
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
You could buy an adapter. I have lne that mounts to the mirror and draws power from the mirror.
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Base does not have power at the mirror
1970AMCAMX
Robert
Titusville, FL
It's pretty easy to run a wire to the mirror from the fuse box just tucking it under the trim around the windshield on the drivers side, then pull the grab handle to run the wire to the fuse box. Just hook it to a fuse that is powered when the ignition is on with a fuse tap.
Ground_zero298
Scs michigan
Can buy them for a couple bucks on Amazon. I added 2 to mine.
ColonelAngus
Jon
PA
2023 Badlands, 07 BMW 335i, 05 Saab 9-5 Aero
Also if you care to take the plunge.... Smart phone connectivity with sync has surpassed the dedicated GPS devices.... one less device to have to worry about. If not, i'll get of your lawn.
1970AMCAMX
Robert
Titusville, FL
Yes it does, at least the 2022 does.
There must be a difference between 2 doors and 4 doors, my 22 base does not have power at the mirror
rgalvinmi
rgalvinmi
Bob
my 2022 base 2 door, 2.3 7mt, has ZERO options...not 1.00 in options. Has power mirrors right by the window switches on the center console.
1970AMCAMX
Robert
Titusville, FL
Not talking about power side mirrors, the rearview mirror on the windshield doesn't have power going to it so you can't tap into it for radar detector power.
