- First Name
- G
- Joined
- Nov 26, 2021
- Threads
- 12
- Messages
- 497
- Reaction score
- 341
- Location
- Sacramento
- Vehicle(s)
- White Wrangler JK, White Bronco Base 2Dr
- Your Bronco Model
- Base
- Thread starter
- #1
I'm about to charge my battery after sitting for a couple of weeks. Looking at a chart it looks like its at 12.2 volts which equates to 60 percent.
My question for anybody that knows... is it possible to hook a tender to the Bronco without disconnecting the negative terminal?
In the Bronco owner's manual it states the following, and it sure seems like a lot to have to go through to keep the battery charged up.
Anybody have experience with this???
Battery Management System Limitations
After battery replacement, or in some cases after charging the battery with an external charger, the battery management system requires eight hours of vehicle sleep time to relearn the battery state of charge. During this time, your vehicle must remain fully locked with the ignition switched off.
Note: Prior to relearning the battery state of charge, the battery management system could temporarily disable some electrical systems.
