Hey everyone, looking to see if anyone has installed a BDS KOH Coilover lift and how you like the install and ride quality.
Open to suggestions of recommended brands.I would rather buy tuned suspension from someone who will take care of me. BDS is more like a parts seller not a custom tuning shop. For that kind of money you want someone that offers free tuning and adjustments.
Post what you are looking at doing with your Bronco, weight like winch/bumpers and tire size you want to run. Several people on here with custom tuned shocks should be able to help sort out the differences for your needs.
If you just want adjustable coilovers 4wp are a killer deal right now. I am cheap so this is as far as I will most likely go myself.
https://www.boss4x4.com/product-p/4wp8-52233bx-1.htm
https://www.boss4x4.com/product-p/4wp8-52233bx-2.htm
Side note if your going to run hard, full steering upgrades first. Like blowing the money on a full billet 74Weld Stage 3 Rack. Lift off seems to kill tie rods lol.
74Weld and BroncBuster both have parts to replace one side of the steering rack and put a bushing on the other. That is FAR cheaper than replacing the whole rack. I think the 74Weld option is both better and cheaper, but that is my opinion. Other than that I would either replace the Tie Rods or brace them. BroncBuster has the braces. There are a LOT of options for replacement Tie Rods.Do you have any other recommendations if the 74Weld is out of budget? I plan on running 37s, and have a 4" lift that's not been installed yet. I'm waiting until I can decide what I'm doing for my tie rods and steering components - I plan on wheeling a good bit, most of which is pretty moderate but do want to and plan on hitting some harder trails and obstacles when I have the chance
Yeah I've seen quite a few braces or replacements, I just want to make sure I do all my research before buying something, because I don't want to brace or replace them and then put my steering rack at risk. Tie rods are much easier and cheaper to replace Just want to make sure I'm doing it correctly and not screwing myself in the long-run74Weld and BroncBuster both have parts to replace one side of the steering rack and put a bushing on the other. That is FAR cheaper than replacing the whole rack. I think the 74Weld option is both better and cheaper, but that is my opinion. Other than that I would either replace the Tie Rods or brace them. BroncBuster has the braces. There are a LOT of options for replacement Tie Rods.
The bushing and housing end for the Stage 1 for HOSS 2.0 from 74Weld is $1000. Both sides get oil impregnated bushing. Then you need Tie Rods or Braces. I think Tie Rods are better than braces. The Ford Performance Tie Rods are $320. So for $1320, install on your own and get an alignment and you are set. If you are just ok with working on cars this is a 1 day project.Yeah I've seen quite a few braces or replacements, I just want to make sure I do all my research before buying something, because I don't want to brace or replace them and then put my steering rack at risk. Tie rods are much easier and cheaper to replace Just want to make sure I'm doing it correctly and not screwing myself in the long-run
I appreciate the input!The bushing and housing end for the Stage 1 for HOSS 2.0 from 74Weld is $1000. Both sides get oil impregnated bushing. Then you need Tie Rods or Braces. I think Tie Rods are better than braces. The Ford Performance Tie Rods are $320. So for $1320, install on your own and get an alignment and you are set. If you are just ok with working on cars this is a 1 day project.
BroncBuster has a similar bushing and housing end but is more expensive. The housing end by itself is $1189, the bushing is $349. The bushing is plastic and the housing bushing is just smooth aluminum. The Braces are $399. They have a package of all three for $1729.
I think BroncBuster's bushing is inferior to 74Weld's. I think the housing ends on each are similar but 74Weld's have an oil impregnated bronze and BroncBuster's doesn't. I think the brace is more expensive and not as good as better tie rods.
So, based on all that, I would recommend recommend the 74Weld Stage 1, upgraded Tie Rods and an alignment. It is cheaper and better than BroncBuster's.
Your steering will be as strong as you can make it without shelling the $4k to $5k and downtime for the whole steering rack replacement.
This should be the first thing people do to their Bronco if they plan to off road (rocks ore desert runs) because this the Bronco's weakest link and will eventually leave you stranded. Getting your rig out and fixing after breaking down will cost you more than preventing it. Everything else (shocks, bumpers, lights, etc.) come after.
That is my 2 cents.
Holy shit that’s a good deal. I might have to jump on that. I was gonna put SVC collar spacers on Badlands Bilsteins - but; this is a steal.Post what you are looking at doing with your Bronco, weight like winch/bumpers and tire size you want to run. Several people on here with custom tuned shocks should be able to help sort out the differences for your needs.
