Is there a link & spec. to the Hatachi shocks?
I was going to do the Bilstein 5100 on my Base.
Would the Hatachi be a better option?
Rightnow I get 19 so it probably go down to 16Haven't noticed a difference yet, but I'll report back on that as well over a bit of time. It's gotten 16 mpg since we first got it and I haven't seen a change from that yet.
Would you say you now you have the same clearance/ride height as a badlands bronco?I'm a bit late to post this, but I figured better late than never. I picked up a set of non-sas Badlands Bilsteins off of someone here on the boards and swapped them with the Hitachis at the beginning of this month. I have not driven it off road yet, which will come later in the summer (I'll give my thoughts on that at that time), but I have driven maybe 500 miles in city and highway driving situations since the swap was completed. Just figured I would give everyone my current thoughts in case anyone else is thinking of doing the same swap.
First of all, I'll give you some basic measurement differences (which actually don't make sense to be honest), so keep in mind they may be a bit off. I measured with a full tank before and after to get the height increase comparison numbers in my garage parked in the exact same spot. I did measure just 4-5 days after the swap though, so maybe they could have settled a bit since then? Pretty much removed the rake out of it and I'm not sure if I'm okay with it yet. I'll double check here when I get a chance, but here are the initial numbers:
After the swap:
Front lift increase of 1.5"
Clearance increase at bottom of transmission skid of 1"
Clearance increase at bottom of rear trailing arm mounts of 1"
Rear lift increase of 1"
Before and After Side shot:
Front 3/4 view Before and After:
Impressions:
- Ride control is much better. After now having the Bilsteins, the Hitachis were possibly underdampened. Huge improvement/reduction in bangs over road imperfections and the ride is much smoother overall.
- Highway ride is the city driving improvements, but to the next level. Much nicer for a long drive now.
- Noticeably less nose dive and more body control. Feels more "planted" while driving which has been a big bonus.
Yep, we're gonna ago with 33s or 34s when the Grabbers wear out as well, but they will have to do for now. But overall, If anyone is thinking about doing the swap, I wouldn't hesitate. I was looking for a simple upgrade to the Hitachis, and I am more than happy. I'll definitely report back with some off road impressions this summer as well, but I figured I would at least give everyone my initial impressions.
You actually already have the Hitachis. They are the stock shocks for all models below the Badlands non-sas models.Is there a link & spec. to the Hatachi shocks?
Yeah, I'm guessing we'll take a hit, so we'll see.Rightnow I get 19 so it probably go down to 16
I did not do the install myself, just due to time and some other reasons, but it shouldn't be a very difficult install especially if you have done suspension work before.Were you able to install them yourself? I'm thinking of buying SAS takeoffs with the coilovers already attached, am hoping that I can install myself.
With the tire difference, it's tough to make a direct comparison, but it almost seems like it's at least equal, if not a bit more in the front than a standard Badlands.Would you say you now you have the same clearance/ride height as a badlands bronco?
Install is not bad. I did a coil over swap on my ranger and it was pretty easy to do. I do not anticipate install being very tedious here either.Were you able to install them yourself? I'm thinking of buying SAS takeoffs with the coilovers already attached, am hoping that I can install myself.
With the pictures you posted those are 33” tires on your bronco?You actually already have the Hitachis. They are the stock shocks for all models below the Badlands non-sas models.
rake reduction could be from the Bilsteins coming from a V6 or Auto bronco and this BD may not have both.
While I think the BD has the same plating underneath as the BL, the BL has the Swaybar Disconnect which weighs more. So, I am guessing there is where the weight difference is.Yeah, still trying to figure it out, but I'm going to roll with it for a while.
Yeah, that's the odd part. It took me months to find this set that was off of a hardtop, V6 Badlands (most the sets available were coming off if 2.3s) so it would be most closely matched with mine. Only difference between the two vehicles (besides the model of course) is the tow package, and that doesn't make a difference in the shock or spring model numbers on the Badlands. Who knows. Since it doesn't have a noticeable "squat", I'm just gonna see if it changes over time.
They are 32s.With the pictures you posted those are 33” tires on your bronco?
Agreed. Tire size has a lot to do with it.I see people posting about Hitachis, 5100s and SAS take offs.
Hitachi shocks ride perfectly fine with stock tires, they have plenty of resistance to control stock weight wheels and tires. SAS shocks are a substantial upgrade over the Hitachi shocks in the control department. They should have been standard on all Broncos as they are a good mix of offroad and onroad control (hitachi fall short on freeway driving around curves with expansion joints). 5100 have a more aggressive valving than SAS and are an improvement when you go larger tires. I like the video below, its about the best review I have found on SAS shocks vs cheap 5100s. Note the heavier the tire the more shock you need to control it.
The op would most likely prefers the SAS shocks due to the stock tires. Stock tires and 5100s may be to harsh and something people should think about. 5100s and 35x12.5 tires are a pretty nice combo but not something I would run on stock tires.
Do you have link to the tires? Was thinking of getting the same onesThey are 32s.
